RV.Net Open Roads Forum: Tow Vehicles: Dodge CTD Manual Transmission Fluid Change
Search only in Tow Vehicles
 > Dodge CTD Manual Transmission Fluid Change
Lynn Rupper
Ohio and everywhere else
Posted: 07/15/06 04:37pm Link  |  Print  |  Notify Moderator
The owners manual on my "03" Dodge Cummins Diesel calls for Automatic transmission fluid in the 6spd manual transmission with no interval to change it out. Has anyone changed it out to a Synthetic auto trans fluid and at what interval? Also wondering if it would void the warranty.
2003 Dodge Ram 2500 CTD, 6spd manual
1995 HitchHiker II
Full-timer 1995 to 2009
Snowbird/extended RV'er 2009 to ?
SEMPER FI
JIMNLIN
out here
Posted: 07/15/06 07:10pm Link  |  Print  |  Notify Moderator
Redline MTL synthetic. Changeg mine at 30000 miles. Check dieseltruckresource.com web for other brands thats popular with the Dodge NV5600 crowd. See myoilshop.com for info and pricing.
JIM
'97 Park Avanue 28' 5er 11200 gvwr two slides
The HitchHikers
Gold Bar, WA
Posted: 07/15/06 08:02pm Link  |  Print  |  Notify Moderator
If you have the NV5600 it does not use auto transmission fluid! Unbelievably the manual says it is not necessary to change the oil in the tranny but only to check it an top it off. I think it should be changed just like all the other fluids.
The Redline MTL is a good replacement but the oil called for by the Owner's Manual is Mopar part number 4874464 and this should be in the back of your Owner's Manual.
Type "part number 4874464" into a google search and read up on some of the links.
Pennzoil/Quakerstate Synchromesh same as DC Manual Fluid 4874464 (GL-4 spec)
Check the below link for some other information.
http://www.turbodieselregister.com/LIQUIDS.pdf
Steve and Gayle
2004.5 Dodge 3500 4X4, SRW, QC, SLT, LB, NV-5600, 3.73 AS, 325/600 Cummins
Todd Barney
Atlanta area, GA, USA
Posted: 07/15/06 09:44pm Link  |  Print  |  Notify Moderator
You're not thinking of the transfer case, are you? That one uses Automatic Transmission fluid.
2006 Maxlite 30BHS
Maxlite Photos
Large: 2003 Dodge Ram 2500 Quadcab 4x4 V-10 5spd manual 3.73
Equal-i-zer, Prodigy
Medium: '07 Infiniti G35S
Small: '91 Miata
Pad the walls, we got 10-yr-old twins in here!
csamayfield55
Sparks Nevada
Posted: 07/16/06 02:41am Link  |  Print  |  Notify Moderator
I know mine is a NV4500 but as others have said, mine takes a special part # fluid. I had to replace the 5th gear nut and part of that was to drain the fluid out of the trans. My truck has 186K on her and was getting kinda hard to get into gear. When I put in the new fluid it was like a brand new trans!! It would go into 2nd and reverse better than ever!
So, yes, I would change it, but not till 100K miles
Chris
2008 Dodge Ram 3500 6.7L Cummins Quad cab
Tekonsha P3
2005 Keystone Sprinter 295DBWS
www.ATVEXPLORERS.com
klenger
Tucson AZ
Posted: 07/16/06 07:39am Link  |  Print  |  Notify Moderator
NV-5600 Transmission Fluid Change
2008 Tiffin Allegro 32BA FRED Class A Motor Home
Looking at trading for a Winnebago Access 31C Class C
Lynn Rupper
Posted: 07/16/06 08:35am Link  |  Print  |  Notify Moderator
Thanks for all the info. Somewhere I thought I read in my owners manual that Dodge used auto transmission fluid in the NV5600 6spd manual tranny. However, after re-reading my mannual, I quess it was a case of old age. Anyway thanks for the all of the good advice. I will be changing my transmission fluid soon, as I have 66K miles on it.
The HitchHikers
Gold Bar, WA
Posted: 07/16/06 09:12pm Link  |  Print  |  Notify Moderator
One last note, before you drain the fluid make sure you can get the fill plug out. I have read where some people have had a problem getting the fill plug out and that could be a problem if you had already drained the oil out of the tranny. I changed out the O2 sensor in my last gasser and it took about 3 days worth of trying and soaking with penetrating oils before it came loose.
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
