RV.Net Open Roads Forum: Dometic Refer Recall - Possible Fire Hazard -Update 2/13/07
 > Dometic Refer Recall - Possible Fire Hazard -Update 2/13/07
Page of 84
Tech Issues Related Tips
socalrvers
Temecula, CA
Posted: 02/15/09 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
I just had my RM 2852 recall work done at Mike Thompson's RV in Colton CA, now the fridge lights wont come on. Does anyone have any idea I checked the circuit board in back the fuses seem fine..Please help..
Dreaming of Full-Time RVing? It's time t........er details! This Guide gets you started.
Hey check out this new Travel Trailers p........groups.yahoo.com/group/traveltrailers/
Chris Bryant
DeLand, Florida, USA
Posted: 02/15/09 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
The recall adds a couple of safety devices before the circuit board. A fairly common problem is when the new wire between the junction block and the first thermal fuse isn't making a good connection (which should be caught when the service center *tests* the recall installation).
Check for 12 volts at the thermal cutoff riveted to the chimney- both sides.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
timsrv
Battle Ground, WA
Posted: 02/15/09 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
It's also possible he grounded the 12v power supply and blew a fuse inside the RV. I've also seen poor installs where wires were pinched by the new sheet metal. Tim
socalrvers
Temecula, CA
Posted: 02/16/09 12:35am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the fast replies, I will check it and post fix.
DennisMiller
Blind Bay BC Canada
Posted: 03/05/09 04:56am Link  |  Quote  |  Print  |  Notify Moderator
I am wondering if the DM fridges are not part of the recall. The notice lists RM units and supposedly they have been renamed to DM because of 10 years worth of serial numbers! Does "DM" mean that they will just have a problem in a few years or does it mean something has also changed on the units??
To clarify...I have a DM2652 unit but the RM2652 units are being recalled, so the DM2652 is OK??!
stephenl
North York, ON
Good Sam RV Club
Posted: 06/29/09 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
I am wondering the same thing. My model is DM2652 as well. My serial number starts with 75 so as best as I can tell it was manufactured in May 2007 if a previous poster was correct that the first 2 digits are the year and the month. I hope it's not affected as I'm leaving on a camping trip tomorrow.
2009 Discover Canada RV Kokanee Express 19CK-C
2006 Chevrolet TrailBlazer EXT LT 4.2L
Reese 750# WD w/ dual cam sway control
Husky Excursion proportional brake controller
My Pictures: http://photobucket.com/kokanee_express
mwjw
Scranton Pa.
Posted: 08/28/09 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Did we ever find out if the DM2652 is affected by the recall? Mine was built in 2008.
mark
jbman
New Boston,Michigan
Good Sam RV Club
Posted: 09/01/09 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Well my Dometic Refrigerator went out. Going to let Camping World put a new one in. Am wondering if the new units will work longer than the last or should i expect 3 yrs of service than a leak all over? Also i want to make sure i get a unit thats new and not one thats been sitting around along time. Guess it probally won't matter, what do you guys think?
* This post was edited 09/01/09 08:21pm by jbman *
Rangerdave
Austin Texas
Posted: 09/02/09 12:49am Link  |  Quote  |  Print  |  Notify Moderator
HEH-- good luck on any of that..
RD
2002 Gulf Stream Ultra Supreme-Demco Kaddy SS Toader Camry
2 peeps 2 poops and lots bbq!
No Fuss Flush
Before you give someone a piece of your mind, be sure you can do with what you will have left.
DennisMiller
Blind Bay BC Canada
Posted: 09/02/09 03:53am Link  |  Quote  |  Print  |  Notify Moderator
mark
I believe my 2652 installed in 2008 has the sheet metal fix. Really impressive! The RV industry needs some oversight.
Page of 84
