RV.Net Open Roads Forum: Dometic Refer Recall - Possible Fire Hazard -Update 2/13/07
 > Dometic Refer Recall - Possible Fire Hazard -Update 2/13/07
Page of 82
RVN'S 4 US
On the Road
Posted: 11/05/06 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Since the notice says that the problem requires all 5 elements, and the later units that returned to the smaller element are not part of the recall, it would seem like the best cure is to have the recall based on installing the 325 watt element.
Edit: Oh yeh. And hire a better welder to do the welding on the parts that replace the ones that get the fatigue cracks.
* This post was edited 11/05/06 12:21pm by RVN'S 4 US *
Plan for tomorrow. Live for today. Learn from yesterday.
va_jay55
Orange County, VA
Posted: 11/05/06 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Got the model, but not the serial #. Whew. Dodged that bullet. Thanks RV gods.
* This post was edited 11/05/06 06:23pm by va_jay55 *
Jay, Gay & the Kid Cyd . . ... Pics . . . . . Elk Neck Rally 9/26-28/08
Ford E350 XLT Super Duty . . . . . . ......... 2007 Rockwood Roo 233
Prodigy . . .Equal-i-zer 1K/10K WDH . . .......... ........................
stevenal
Newport, OR, USA
Posted: 11/05/06 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
You would think the serial number would cross to the element size. Mine also is labeled 2.7 A, but serial and mod numbers match the list.
'99 Bigfoot 1500
with low loss control on the Fantastic, Dino board on the Dometic.
Torklifts and Fastguns
'04 F350 V10 Crew SRW SB 4X4 6 speed
with tow hook replacement, dual rate charging, Line-X, Timbrens.
HaroldG
So. Cal
Posted: 11/05/06 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Phil,
Sent you a PM.
Harold
roman traveler
Madera, CA.
Posted: 11/06/06 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Mine also says 2.7A on the door sticker, but when I opened the outside panel, on the black box that has the fuse it says 2.9 A. Now I'm really confused. Bottom line, I think I'm stuck.
RT
vcrazy8
north Alabama
Posted: 11/06/06 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Where is the heating element in the fridge anyway? Mine says 2.7 inside and 2.9 outside also.
HaroldG
So. Cal
Posted: 11/06/06 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds to me like Dometic didn't change their sticker on the inside door from 2.7amps to 2.9amps.
Harold
Beddows
Abbotsford, Canada
Posted: 11/07/06 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Our organization has someone checking with Dometic (who has a pipeline to the top) on this. If I find out anything I will post it.
2004 Chevy 3500 Duramax DRW
2008 Snow River Prestige Signature Edition. (The first of its kind)
balvert
Windsor, Ontario
Posted: 11/07/06 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
I emailed Dometic and they gave me a number to call for information (1-888-446-5157). It is an automated system that takes your name and phone number. Unfortately it does not work for Canadians with postal codes as you have to use a touch tone phone to enter your ZIP code. So I called them directly and spoke to a gentleman that took my info. Said they were fixing the automated system to allow entry of the Canadian postal codes. He did say that he thought the fix was going to be relatively simple. Only fix I can see would be to replace the element.
vcrazy8, the element is next to the propane chimney that is located on the right side of the compartment as you are facing the cooling unit from the outside. You can see the end protruding from the sheet metal cover and there are two wires attached to the element.
Casey & Karen, Border Collies, Polly & Babe
04 Newmar Mountain Aire 34RDCK with tandem duals & XPS Ribs, Pullrite 25.5K Super 5th, MorRyde, Solar, RotoChoks
03 Dodge DRW Sport, Cummins, 4.10, 6 spd, MBRP SS Exhaust, Jacobs E-Brake, Tire Sentry, BrakeSmart
BillWing
Sandpoint ID
Posted: 11/07/06 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
Absorption refrigerators use as refrigerant R-717 (ammonia), R-718 (water - yes, water has an "R" number), and hydrogen, with a corrosion inhibitor added.
As flammable as hydrogen is, when it escapes it goes UP very quickly, as it has a very low density even compared to helium.
Ammonia will burn, if atomized (like hissing out of a cracked cooling unit tube), in the presence of a flame, and in its range of flammability as mixed with air.
Once leaking all the hydrogen will escape rather rapidly.
Hopefully Dometic will move quickly as not only is this somewhat of a fire hazard, the refrigerators won't work without refrigerant (uvcawss!). The amount of refrigerant is fairly critical for efficient operation (as efficient as the inefficient absorption process is), so the cooling will drop quickly once leaking begins.
Page of 82
