RV.Net Open Roads Forum: Towing: travel trailer vs. fifth wheel
Search only in Towing
Open Roads Forum  >  Towing
 > travel trailer vs. fifth wheel
larrytroy
lafayette, louisiana
Posted: 03/24/02 01:19pm Link  |  Print  |  Notify Moderator
I am preparing to purchase either a travel trailer ot fifth wheel for full timing. I am told that there are hitches for trailers that can compare favorably with the stability offered by fifth wheels. Anybody using one of these hitches who has first hand knowledge as to how they perform?
wittmeba
Virginia
Posted: 03/24/02 05:33pm Link  |  Print  |  Notify Moderator
I suspect you can request a video from most TT hitch manufacturers. I sent for the SuperSlide (for the 5th wheel) and the tape included both 5th wheel and TT hitches. I was quite impressed with the improved technology implemented with the TT hitches and gained a lot of knowledge.
My wife used to give me $1.00 each workday for lunch. After a long argument, I won. Now she gives me $5.00 every Monday.
"On any given Friday night, more kisses begin with Miller Lite than Kay.".
Firefox® 12
AV, Malware and Disk Utilities
Log home
BurbMan
Louisville, KY
Posted: 03/25/02 06:26am Link  |  Print  |  Notify Moderator
Larry, the "premium" hitches for TTs are the Hensley arrow and the Pullrite. Take a look at www.hensleymfg.com or www.pullrite.com.
These hitches minimize or eliminate (depending on your opinion) trailer sway by moving the pivot point of the hitch forward to the rear axle of the tow vehicle. TTs sway because the pivot point (the ball mount) is behind the rear axle of the tow vehicle by several feet. 5ers are inherently stable because the pivot point is directly above the rear axle of the truck, like a semi setup.
The Pullrite mimicks this setup by mounting under the frame of the tow vehicle and physically moving the pivot point to just behind the rear axle. The Hensley uses a conventional receiver mounted on the tow vehicle, and uses advanced geometry to create a "virtual" pivot point at the rear axle of the tow vehicle.
From what I have read, both are equally effective, both have plusses and minuses. Both are expensive at almost $3000, but both can be found used at substantially less.
I would suggest doing a search on this forum using "Hensley" and "Pullrite", you will get a lot of useful info. I have just ordered a Hensley, I found that best for my particular set-up.
Don
LAdams
Northern Illinois
Posted: 03/25/02 07:35am Link  |  Print  |  Notify Moderator
Burbman (Don) gave an excellent explanation...
I tow with a Pullrite and can attest to it's stability... It is essentially as Burbman said - - a fifth wheel hitch UNDER the truck...
Both the Hensley and Pullrite offer excellent towing stability and ELIMINATE any sway...
Either one will provide excellent results...
Best Regards,
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
bluenote
Michigan
Posted: 03/25/02 11:14am Link  |  Print  |  Notify Moderator
I really enjoy the stability when pulling our 5er, and what I feel is better manuveuring capability with this set-up. One question on the hensley or pull-rite though....how are they for backing up? Are they more like the 5er's or a regular TT? Although I don't see making an RV change anytime soon, it would be nice to have the full truck bed available for storage, and maybe someday we'll change over.
gregorio
Colorado
Posted: 03/25/02 11:47am Link  |  Print  |  Notify Moderator
hensley claims to pull better than a fifth wheel trailer. i dnp't own one, but if this is true, you may find a better floorplan with a tt than with a 5th wheel. plus, there are no stairs.
Gregor
2003 Ford Expedition 5.4 liter 4x4
2001 KIT Companion 222TLE Travel Trailer
Brettnandrea
new jersey
Posted: 03/25/02 05:45pm Link  |  Print  |  Notify Moderator
i don't know how you could get better then a 5er, maybe the same(don't know never used a hensley). my parents just recently upgraded to a 36ft 5er and can't believe the differce from there tt. they have told me they don't even know that a 18 wheeler is passing them untill they see it next to them, no sway at all. after towing many years with many trailers and now for about a year with a 5er, they have said they will NEVER go back to a TT.
besides that you are alot shorter going down the road. a 35ft 5er has 35ft of usable space. a 35ft TT has about 32ft of space. also when towing about 5ft of your trailer is over your truck, shortening your overall length.
most(not all) floorplans you find in TT can be found in a 5er, with the addition of steps. its a personal choice, but i know my next one will be a 5er.
Brett, Andrea, & Kelly
2002 Dodge 1500 5.9l 4x2
2001 Mallard 27h
BurbMan
Louisville, KY
Posted: 03/25/02 06:09pm Link  |  Print  |  Notify Moderator
Brett,
You point out several good advantages of a 5er vs. a TT, however, you neglected to include the tow vehicle in your comparison. We need the 3rd seat in our Suburban for carrying folks and friends to non-camping destinations, so a pick-up is not an option for us, even a crew cab. Even camping, the 3rd seat is good for the 2 dogs. So, we without a pick-up, we are limited to a TT. My wife and I have decided that in future years when it's just the 2 of us, we'll either go 5er or MH. Just my .02.
Don
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
