RV.Net Open Roads Forum: Tow Vehicles: 2007 Dodge Mega Cab
Search only in Tow Vehicles
 > 2007 Dodge Mega Cab
ToyCrate
Visalia, California
Posted: 01/06/07 01:06pm Link  |  Print  |  Notify Moderator
mthisguy wrote:
Call it a "Cummings" again and those cowboys might string you up. You drive a Cummins, cumming is something you do at home.
You beat me to it
dhigley
Oregon
Posted: 01/07/07 01:59pm Link  |  Print  |  Notify Moderator
Has anyone put a chip in their dodge truck yet? If so what brand and how did it perform?
Thanks for the input!
mthisguy
wy
Posted: 01/07/07 04:24pm Link  |  Print  |  Notify Moderator
Theres lots of choices but be aware you chip or retune it and Dodge wont warranty it. Also dont even consider chipping a TV without a full set of gauges. The EGT's on the new CTD run pretty high stock. You'll find out you dont need it chipped to tow well anyway.
JIMNLIN
out here
Posted: 01/07/07 07:56pm Link  |  Print  |  Notify Moderator
check with the Dodge/Cummins folks at turbodieselregister.com and dieseltruckresource.com for lots of answers to your tech questions.
JIM
'97 Park Avanue 28' 5er 11200 gvwr two slides
jam1on1
newburgh,ny
Posted: 01/09/07 04:53pm Link  |  Print  |  Notify Moderator
i would like to know how jkaufmann ordered his truck and it will be here in four weeks ordered mine in mid december and its still in bg status ?
2007 dodge megacab dually 3500 laramie ,sunroof ,nav radio, inferno red,pulling a 2006 sunnybrook fifth wheel 31bwks
ptgarcia
Fontana, CA
Posted: 01/09/07 05:00pm Link  |  Print  |  Notify Moderator
dhigley wrote:
Any body changed out the tires for larger tires... 285's? If so has it done anything to the handling?
I have 325/70-17s Toyo Open Country ATs on mine. I also added King shocks, CSS coilsprings and Deaver leafsprings and it now rides better, handles better, tows better and is an animal running fast in the desert!
Pauly
Travel Trailer: 2005 Thor Jazz 2510FL
Tow Vehicle: 2006 Dodge MegaCab 3500 4x4 Cummins Turbo Diesel
woodrow
PNW
Posted: 01/09/07 05:34pm Link  |  Print  |  Notify Moderator
If you had a chevy d/max before, which I think you said you did, you know that it is possible to do the cumming thing even while driving
'07 2500HD D/Max-Ally,Firestone Compressor and Air Bag's,285 BFG's,8" MB Gunner Wheels,TB MBRP Exhaust,Edge Evo with Hot 5,6,7 Levels,3 Spd.High Idle Mod,VVT Exhaust Brake,Torklifts/Fastguns/Stable loads "Yellow Lab Louie"
ToyCrate
Visalia, California
Posted: 01/09/07 07:04pm Link  |  Print  |  Notify Moderator
I wanted a set of gauges and shopped around quite a bit. I ended up buying a Juice/Edge/Attitude module to monitor everything but the tranny temp. My local Dodge dealer recommended it and said that they have installed many before. I purchased a separate pillar mount tranny gauge. I LOVE THE JUICE!! It monitors (with the exception of tranny temp) everything! EGT, engine temp, boost, rpm, engine load, air box temp, torque converter lock, slip, and it will display actual speed based on tire size!. Not to mention that at the push of a button, you can bump the power up to amazing levels. It was expensive, but I do use it all the time. It is nice to have the ability to monitor everything. If I were to buy everything separate, it would have been a lot more expensive. Since you need to have gauges if you are going to boost the power/performance, the Juice module is the answer in my opinion.
ptgarcia
Fontana, CA
Posted: 01/09/07 08:19pm Link  |  Print  |  Notify Moderator
I prefer the Quadzilla Commander over the Attitude, it has more capabilities.
k6wlt
Loyalton, CA
Posted: 01/15/07 10:33am Link  |  Print  |  Notify Moderator
That black 3500 is a thing of beauty! I love the black wheels.
What is the concensious on 5th wheel towing with that short bed? Extended kingpen or ?
I have a 16k Reese sliding hitch...on my Ford I only have to slide it to get in my driveway...but it's optional...and I have the short bed.
Can you get away with no sliding it often or is it a constant thing with that bed?
2007 GMC Duramax 3500HD Longbox 4x4
05'Vortex 325WTB 5th Wheel Toy Hauler
05'KTM 525 EXC
04'CRF 150
09 TTR-50
07 TTR-90
01'Suzuki JR50
98'Polaris Sportsman 500
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
