KarenInTheWoods
Wisconsin
abbieflash wrote: One tip I would suggest is, to keep your tools stored in the curbside storeage bins.If you have a breakdown while on the road, you are not close to the traffic trying to get to your tools
Yes, and keeping in mind the weight distribution requirements of your rig, we needed more on the passenger side anyhow. Below is a photo of hubby dear's invention of his heavy duty Tool Drawers .....
Karen and Steveio
1996 Safari Serengeti 38 ft DP
Honda Helix up on back rack
(Camping/Family Photos) http://picasaweb.google.com/pfundt/
www.kareninthewoods.com
billyboy
md
i pop riveted a bag clip to a blank ignition key and clip it on the antenna crank, and when i put the antenna up, i slide it in the ignition ,so you have to take it out before you start the engine.
Remember: "Its Not The deal You Got, Its The Deal You Think You Got"
'08 Windsport 33 followed by 2000 Saturn
utahron@sginet.com
St. George, Utah
I use a Potato Chip bag clip which I put on the antenna crank. When I raise the antenna, I put the clip on the steering wheel. Can't miss it there.
norwestie
West Linn, OR
Over the last 10 years we have purchased new two travel trailers and a Class A motorhome. No one at any of the dealers mentioned the following tip: don't dump the black tank when pulling up stakes. Drive to the next campground and let the stuff slosh around. then when you arrive and hook everything up, dump the black and start over again.
jimj
Southern IN
Lots of good tips here.
Carpet samples are 27" wide and my steps are 27" wide so I cut them in half or to fit and have a bound on 3 sides carpet for the steps. They are cheap so you can change them out when durty or you want to change colors.
JimJ
jeffnkelly
St. Louis MO
George B wrote: I have my lables with the license number of my coach and toad attached to my FMCA card so I have all of my information with me when I register at an rv park.
hehe... Thats what the DW needs instead of me... When asked for that kind of info she give me that.. you know... "Look".
Good Idea!!!
Smooth Roads!!!
2006 Damon Challenger 372F Triton V10
2007 Ford Edge
JeffnKelly
St. Louis MO
dakotaman
Oshawa, Canada
Hi All
I have carpet runners I put down to the cockpit and along the floor in front of the driver's seat when I take the MH in for service. In the past we have had stains on the carpet from the mechanics boots. Easy to take up when they are done and store in the basement.
Dakotaman
Sent from my PC because I do not have a Blackberry
sootslayer
Central Pennsylvania
extra keys
Hank
Anthony21403
Arkansas
I have one that will also help with the "fat wallet" as well as the "sweaty money" problem. When I was deploying last fall, I carried my cards and cash in my pocket, but while out with friends I lost my govt travel card. Next day while down in the hotel gift store I found one of these Waterproof Carrier
I run the lanyard through a belt loop, then drop the carrier through the loop. My money, id, and credit cards are all secure and dry. Even though I am back in the States I still do this.
TSG Tony, USAF, 17 years
maxmorrow
Birmingham ala.
We go to the "Dollar Tree" and get the metal black paper clips and they can be used for all kinds of uses. We use them to hold up our "tacky" lights on the awning flap, keep curtains closed, and as chip clips. You get several sizes for only a dollar. I also take and cut plastic funnells to go around each cord (put tape over cut to seal it tight to cords) or hose connected to MH with large end facing down and sprayed inside with PAM to keep out ants. They cannot hold onto the slick plastic while upside down. John
If you ain't the lead dog...the scenery never changes!!!!
