RV.Net Open Roads Forum: Dinghy Towing: 2007 Honda CRV fuse removal
Search only in Dinghy Towing
 > 2007 Honda CRV fuse removal
othertonka
Stockton, CA
Posted: 05/16/07 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
With the U. S. Gear Brake system, there is a Hot Wire that runs from the positive terminal Motorhome Chassis battery, through a 20 amp breaker, back to the CRV and then through another 20 Amp Circuit Breaker and then to the positive terminal of the CRV battery. When driving the MH, the MH alternator keeps the CRV battery charged. I do turn off the radio and the AC/Heater fan switch. Have towed for more than 20,000 miles and have never had a low battery. This wire is included in the umbilica cord that contains the tail lights, brake lights, turn lights, ground wire, and brake activation wire.
You do not have to have the U. S. Gear unified brake system to add the "Charge Wire". Just look at the wiring diagram at the link below and notice the MH battery, the 20 amp breaker, the CRV battery, and the 20 Amp breaker in the drawing and run your own wire.
Here is the link.
US Gear
* This post was edited 05/16/07 04:54pm by othertonka *
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
The Beave
Georgetown TX USA
Posted: 05/16/07 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
The Beave wrote:
The fuse in our '05 CRV is difficult to remove and replace. We just remove the fuse at the start of a trip and leave it out for the duration. The only problem is the radio does not work and you must place the transmission in park before removing the key, otherwise no problem. I do plan to add the switch before the next trip.
I just got the switch installed yesterday and it works great! I installed the Radio Shack switch in one of the blank switch plates in the dash. I soldered the leads to the the fuse tips I removed from an existing fuse. Very easy.
The Beave
30' 1997 Beaver Monterey
(The shortest DP we could find)
2005 Honda CR-V
Remco surge brake
Mr.Mark
California/Tennessee
Posted: 06/29/07 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Update... I decided to have a switch installed on my 2007 Honda CR-V so that I don't have to remove fuse #34. The repair facility that performed the task did an excellent job. They soldered a wire to fuse #34 and ran a cut off switch on the dash.
On the right side of the steering wheel there is a blank cover on the dash. The technician installed a toggle switch that will turn off the radio/nav. When I toggle the switch back on, everything is perfect. I don't have to reset times, radio stations or anything. The total job cost was $198.
Hopefully, no dead battery in the future.
Mr.Mark
Mr.Mark
2008 Monaco Dynasty, 42ft., 4 slides, 425 hp clean-air Cummins diesel
2007 Honda CR-V EXL, AWD, w/Nav and the M&G braking system
Komvee
Alpine, CA
Posted: 06/29/07 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Most people kill their battery in the CRV by leaving the fan on. Be sure to turn it off or you will kill the battery in a day.
-- Warren
2007 Winnebago 26A
GM/Workhorse Class C Chassis
2000 Honda CRV Toad
MacManOne
Full Time Somewhere in the USA
Posted: 06/24/08 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
Quick question for all, we have our new CRV but haven't towed it yet. Does it accumulate mileage while towing?
Mac
Mac & Chris
1996 Fleetwood Southwind 37Y P30
Internet via Datastorm Satellite or Sprint EVDO Aircard
Full-Time since Sep. 1, 2004
Official RV.NET Blogger for Casino Camping
Personal Blog www.MacAndChris.com
Our Hobby www.CasinoCamper.com
Komvee
Alpine, CA
Posted: 06/25/08 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Mac
No, it doesn't.
-- Warren
2007 Winnebago 26A
2000 Honda CRV Toad
jzick
Davenport,Fl
Posted: 06/25/08 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
We are approaching 5000 miles towing 07 CRV with NAV. I called Honda technical for info on battery/fuse pulling.Tech suggested that up to 8 hours is ok without pulling fuse. When we travel, I simply start the car when we break for lunch/rest, etc. and let it run to top off the battery (Honda suggested) - also gives me a chance to redo the towing transmission set up which, I feel, cannot hurt to recirculate the fluids. If I had to pull the fuse I would install a disconnect switch - fuse is too inconvenient to get to.Odometer does not accumulate mileage unless you leave key at position II instead of I - don't ask me how I know.
Joe and Bonnie
2 Lazy Dogs
07 Allegro Bay FRED 35 TSB
chevylover1965
Southern CA
Posted: 06/25/08 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
We have towed our 2008 for about 6K miles this year. We have the US Gear brake system and have never had a battery problem. As other posters have mentioned, I turn off the NAVI and run through the transmission procedure whenever we stop.
05 Fleetwood Expedition 37U
CAT C7
08 Honda CRV EXL/NAV
Roadmaster Falcon All Terrain tow bar/US Gear
FBINA 144
Mr.Mark
Posted: 06/25/08 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Chevylover1965,
As long as the Navi is on, you are using the battery. I even turned off the screen on my navi but it did eventually run down the battery at 3,000 miles. I even started the Honda at every stop but it was not enough.
I hope that yours lasts longer!
MM.
blucrabbie
Raleigh, NC
Posted: 06/26/08 03:32am Link  |  Quote  |  Print  |  Notify Moderator
Gsmitty77 wrote:
We too took the CRV EX-L/Nav AWD plunge about two weeks ago. Had the Blue Ox base, Stirling All Terain and US Gear brake system installed by San Diego Trailer (no staying power, open 1940's!). Very clean job.
We plan to try towing withoug pulling the fuse, as the US Gear provides power to the toad. I will ask the Dealer for some help on how to turn off the Nav, or hit one of the many CRV boards.
Hope this works out well..
Best to all,
Smitty
Err.. how does the US Gear provide power to the toad? Not clear on this...
New 2 us
02 Winnebago Journey 39QD
08 Honda CRV EXL with Blue OX and US Gear Braking System
FMCA #381833
WIT #W137365
Our Blog
Our MAG1CBUS
hubby and i empty nesters
n4gnn n4hon
I Never Look Back, I'm Not Going That Way!
