RV.Net Open Roads Forum: ARcruiser's Camping Van Conversion Project (lotsa pics)
Open Roads Forum  >  Class B - Camping Van Conversions  >  General Topics
 > ARcruiser's Camping Van Conversion Project (lotsa pics)
Page of 10
ARcruiser
Benton, AR USA
Posted: 04/01/07 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
Gee, it doesn't seem like I brought this van home from WI last July 22nd - that was over 8 months ago!
Guess what? Out of 8 vans owned, this is the 1st that has not caused me a single minute's 'buyer's remorse'. Go figure!
Oh, SHMBO ain't liking it sitting there, but it has not bothered me a bit. We have looked at a couple of other vans in the past 8 months, but in the end I always decide I want to go thru with this project... I'm just gonna hafta get it out of my system - for better or worse.
I have spent a lot of time researching things like 12v and 110v systems (and am still lost), simple plumbing systems, proper thickness of wood for floor and walls, approved hardware for seat belts and installation and on and on.... deciding on what we 'gotta have' in the van, etc. - what lights?, how many?, where?... which refrigerator? how big? 12v only or 12v/110v or 3 way? no propane? what kind of air conditioner? mounted where? rear dinette? rear sofa? 3rd seat on which side?
A few days shy of having it home 6 months I decided that, yes, I'm gonna finish out this van. My 4 year old son helped in this decision. We looked at another van and he was really excited about it... but after a few minutes he said he was looking forward to helping me "build the big van". And said he'd rather "build the big van" than bring home the one we were looking at. Who am I to argue? (don't answer that)
Oh. Here's what I brought home from WI. The previous owner bought this 2 year old cargo van back in '01 when it had 21k miles on it and then had the Penthouse top installed by Sportsmobile's Indiana facility. He installed the 2 rear windows, insulation and some woodwork for bed support and wall panels. The loose wiring and plywood pieces in the floor are just as I brought it home - the wood is for the bed platforms, upper and lower.... 6 months and I hadn't done a thing!
* This post was edited 04/02/07 12:22am by ARcruiser *
2 Big Cruisers, The Little Man, and Bailey / ARcruiser's Class B's (the first 8)
Rig #8 Under Construction! / Here's the Project Thread - I'm actually working on it again!
ARcruiser
Benton, AR USA
INSPIRATION
Aside from Dad's rigs, I'd say my 'inspirational heroes' for my DIY project include the following....
  • Well, most of you have surely looked at Dan's Sprinter Project.
  • Here's the Steyn Family Windsurfing Van on Sprinter chassis.
  • How Gregg did some nice work on his van.
  • Clyde Sisler's van is an important study in my research. While simpler than what I'm shootin' for in some way's, he seems to have the basics and the systems nailed down.
  • ejbleendreeble's Fergus offers important insight as to how to keep things simple, and oft times simple is best! I'll probably end up using a portable a/c unit such as in Fergus.
  • Terry's Westy is the closest I have found to what I have in mind. I have a picture below. His pics are at the Yahoo Westy Group since he has a GTRV installed pop-top on his Chevy Express.
  • Michel Levesque's van is really sharp! He has a fiberglass raised top on his van. See pic below Terry's van.
  • Heather's van.
    Terry's van:
    Michel's van:
    * This post was last edited 05/30/07 08:07pm by ARcruiser *   View edit history
  • ARcruiser
    Benton, AR USA
    Posted: 04/01/07 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
    Soooo... in January the decision was made.... sooner or later I was gonna convert this van. I started ordering stuff and got it into the garage so's maybe I'd do a little work on it....
    Now that was fun. In order to get it in the garage, I had to remove some trim from around the garage opening, tie the door in a more upward position than normal, let the air out of the van's tires down to about 5 psi and have wife and son stand at the back of the van for a little more weight in the rear.... getting it back out was even harder - I had to add several heavy landscaping blocks to the mix to get the van to 'squat' enough to get it back out of the garage! Pics will show how low I had the tires.
    While in the garage, I stripped the original owner's interior down to the insulation. I also removed one of the windows he had installed so I could evaluate 'how he did it' before starting my window installation.
    I made templates and cut the window openings with a 'nibbler'. I installed the window in the rearmost side door and a large window on the left side behind the driver for the third seat. I probably erred too much on the side of caution when cutting, as both holes turned out to be a tiny bit too tight... but that's a lot better than cutting a hole too big, so I got over it.
    Also, the side window never looks straight! But, if measured from the door opening over OR from the bottom edge of the exterior side wall OR from similar measurements on the inside, it always comes out to within a 1/16" of being 'right'.... so that's how it's gonna look.
    Demolition:
    Window Installation:
    Garage door trim reomval:
    Extra weight in the back:
    Accumulated parts:
    Windows installed:
    ARcruiser
    Benton, AR USA
    What am I doing?
    Well, based on past history of owning rather expensive vans that simply sat in the driveway most of the time, and then mostly got used for 'shopping trips', I decided to build something a LOT less expensive that would suit us fine for family shopping trips, daily travel, father/son camping weekends and those rare times that we all would stay overnight somewhere. I doubt that this van will ever venture much farther than 6 hours drive from home base and almost never be out for more than 1 night at a time.... but it will certainly be as capable as any other of being comfortable on longer trips.
    Day and night use as follows:
    I have installed the subfloor, carpet, third seat and three point seat belt for the third seat.
    Another biggie on my list was an Air Bag Deactivation switch for the passenger side air bag. I want the ability to have my son ride up front on our 'bonding trips', so I needed to either remove the air bag or be able to deactivate it. Guess what? The NHTSA does allow for air bag deactivation authorization provided certain criteria are met. A child below age 12 in a cargo van with only two seats (at that time) met the criteria. With authorization given, I was able to order the deactivation switch kit from a GM dealer - once I finally found a parts guy with enough 'want to' to find that a kit was available (it took numerous calls to several dealers before someone finally figured it out - they don't get many requests for deactivation switch kits (most had never heard of such)). I installed the kit today.
    Interior floor shots - stripped the interior from the rear doors to the engine block!
    ARcruiser
    Benton, AR USA
    What's Next?
    Looks like I'm gonna rough finish the walls, install the electrical stuff and rough install the cabinets.... then remove all and cover/paint/stain and reinstall for the final time.
    What's going in? Here's stuff that's installed or in the garage:
  • C R Laurence window in side door
  • Hehr window on left side
  • 3rd seat, track and base
  • seat belt for seat (incl hardware)
  • 1/2" plywood subfloor
  • berber carpet
  • air bag deactivation kit
  • WFCO 25 amp 3 stage converter from BestConverter
  • circuit breakers and disconnect switch for power
  • Marinco 30 amp power inlet
  • Marinco Power Cord and extension
  • Norcold DC-0051 2.7 cu ft refrigerator
  • 20" x 34" table
  • stainless steel sink
  • pump style faucet
  • Easy Curtain for cab section
  • ceramic heater
  • porta-potti
  • Fantastic Fan 12v box fan
    And I still need:
  • AGM battery
  • fresh water tank
  • 12v and 110v wiring and outlets
  • air conditioner and exterior vent/grille
  • fire extinguisher, smoke alarm and carbon monoxide detector
  • wood
  • foam
  • upholstery
  • plenty of odds and ends
    Now that I have made a small bit of progress in the last 60 days, and the weather has turned nice once again, I feel pretty sure that work will start progressing at a more steady pace.
  • markopolo
    Vancouver Island, BC
    Good Sam RV Club
    Posted: 04/01/07 11:49pm Link  |  Quote  |  Print  |  Notify Moderator
    Wow! I'm impressed at what you've done so far. I can't wait to see the finished van.
    I can't imagine cutting the holes for the windows. That took courage. I get nervous just thinking about it!
    ARcruiser
    Benton, AR USA
    Posted: 04/01/07 11:58pm Link  |  Quote  |  Print  |  Notify Moderator
    Thanks!
    I wasn't quite as nervous as when I cut the big hole in the pool liner (for the steps) on the pool I built.
    * This post was edited 04/02/07 12:20am by ARcruiser *
    JoeRT04
    Cape Cod, MA
    Good Sam RV Club
    Posted: 04/02/07 03:48am Link  |  Quote  |  Print  |  Notify Moderator
    Thank you ARcruiser.
    You are the champ!
    Your post came just in time because I was wondering why most of the posts lately were making me "yawn!"
    I love it. I can't wait to see more pics of your progress. And, having your son involved is priceless! He will have wonderful memories of this experience!
    I am truly impressed!
    Joe
    Edited by Joe: Changed "grandson" to "son." My apologizes!
    * This post was edited 04/02/07 05:25pm by JoeRT04 *
    2004/05 Roadtrek 190 Versatile
    FMCA F380826
    My Roadtrek
    Tucson, AZ.
    Good Sam RV Club
    Posted: 04/02/07 04:03am Link  |  Quote  |  Print  |  Notify Moderator
    That's his son, AR is just a youngster!
    Visit My Roadtrek
    Hey, check out the new RV.Net Blogs!
    CAMPIE
    Central PA is home/summers in DE
    Good Sam RV Club
    Posted: 04/02/07 05:11am Link  |  Quote  |  Print  |  Notify Moderator
    What wonderful memories you are building with your son. I admire you for that. This is quite THE project and thanks for sharing with us! Maybe in the future there could be an ARcruiser/ArcruiserJR Van Conversion Company??? Wishing you the very best.....cc
    Barry and Connie
    2005 Gulf Stream Vista Cruiser
    Page of 10
