RV.Net Open Roads Forum: Tow Vehicles: Dodge transmission
Search only in Tow Vehicles
 > Dodge transmission
Page of 5
cillyone
Livermore CA
Posted: 12/26/07 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
I know I am waking up a old thread but I am in the market for a 2001 - 2005 Dodge CTD and it seems like about 1 out of 5 ads I see say "new transmission just installed". Now I am seriously considering just looking for a 6sp NV5600 and do my own shifting, I know how to do clutches myself, not melted-down autos.
Woods
Saint Clair, Missouri
Posted: 12/27/07 02:41am Link  |  Quote  |  Print  |  Notify Moderator
After having a aftermarket vb & TC (goerend bros) in my auto. I'll never buy another manual, and I have changed enough clutches.
TV: 01 Dodge 2500 quadcab 4X4: Cummins,auto(Goerend TC/VB & deep pan),TC lockup switch,gauges,edge comp,rv injec,holley fuel pump,permacool fuel/water filter,big banjo fuel bolts,180 stat,high flow exhaust w/K&N filter.
RV: 26ft 2003 Aerolite.
Dave Wilburn
Ogden UT
Posted: 12/27/07 04:18am Link  |  Quote  |  Print  |  Notify Moderator
That's exactly why I bought an 04 w/ the NV5600. I also like shifting myself.
When I added the Juice/Attitude the stock clutch couldn't handle it above level 3. I got a South Bend CON OFE for $800. Now with the Juice and an EZ, it holds firm. An auto that could do that would have cost me $5K.
ib516
Up here!
Posted: 12/27/07 09:09am Link  |  Quote  |  Print  |  Notify Moderator
I didn't realize this is an old thread and I replied to it a few months back. In any case, mine's still running strong.
* This post was edited 12/27/07 12:49pm by ib516 *
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen (still going)
Collision Reconstructionist
ScanGauge2
marty649
Waycross GA (okeefenokee swamp)
Posted: 12/27/07 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I went to the Dodge dealer in 91 to pick up my new truck, my wife started looking at the Dodge Dynasty and bought one. Never had a trans problem with either, she traded the Dynasty in 94 with 130,000 on a F250 7.3 Turbo Diesel. I sold the 91 CTD in 05 when I bought my current truck. No problems with this one either, but I do all the servicing on all my vechicles, always have always will.
2005 Dodge 3500 Quad cab CTD Dually, Laramie, G56 sbc con-ofe, GPS-NAV, Sirius, intake and exhaust, Gauges, 100 gal aux fuel tank, Rokktech, Quad box, Pacbrake, 85,000mi
2000 Gulfstream Seahawk, Sat TV, Solar, 6.5kw gen, Washer/Dryer
2001 Roadking
cillyone
Livermore CA
Posted: 12/27/07 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Could you guys tell me when Dodge switched from the 47RE to the 48RE, and are there any major advantages to the 48RE? Also, I heard the switch from the NV5600 to the Getrag G56 was in mid 2005, and is there any reason to shy away from the G56 and how do you tell the difference? Last but not least the transition from Dana to American axles in 2003 any reason for concern, any advantages? Any info on these trucks would be appreciated. Thanks in advance.
marty649
Posted: 12/27/07 10:55am Link  |  Quote  |  Print  |  Notify Moderator
The G56 is NOT a Getrag it is a Damiler product made in Brazil.
ib516
Up here!
Posted: 12/27/07 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
48RE came out in the 2003 models, though some still had the 47RE. If the engine is a 305hp/555tq version, and the trans is an auto, it's a 48RE.
The HitchHikers
Gold Bar, WA
Posted: 12/27/07 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
***The 48RE came out in early '03 on the HO trucks from what I have read. Major advantage from my reading is that it is stronger than the 47RE.
***The switch was made about mid 2005 as I have also heard, the way to tell the difference is on the NV5600 the case is made of cast iron so if you look under the truck it will probably be red (rust) and the G56 is aluminum so it will look like the transfer case if it is a 4X4. Also the G56 has reverse gear over to the driver and up or down (I don't remember as I have the NV5600) and the NV5600 has reverse over to the passenger and up.
***I have just under 60,000 on my American Axles and don't have any complaints. You do need to tap the brake to get the Limited Slip to engage when starting from a stop sometimes but there are no clutches to wear out and replace and there are no additives that you need to worry about.
Steve and Gayle
2004.5 Dodge 3500 4X4, SRW, QC, SLT, LB, NV-5600, 3.73 AS, 325/600 Cummins
surveyorjp
Missouri
Posted: 12/28/07 12:26am Link  |  Quote  |  Print  |  Notify Moderator
Also just to add, IIRC there were some issues with the early 03 AAM axles being installed low on fluid. The result was an overheated, underlubricated axle. The reason I know this is I had an 03 Ram Cummins for a couple years and remember reading about this on the forums back then. Mine was okay by the way.
Lots of good info about Dodge trucks here
2005 Surveyor SV-291 Tows smooth as silk!
1995 Dodge Ram 1500 Laramie SLT 4x4 5.9L V8 low miles, It ain't pretty, but it's paid for!
Page of 5
