MPSAN
Portland, Oregon
Our 05/06 LTV is supposed to have 62 front (Wally has changed the front up a bit) and 79 rear. All 4 of mine are 79-80! I asked the dealer and he said they inflate per what is on the tire. He said several tire stores told them that a very low front presure will cause wear on sidewalls and the tire was designed for what is on the tire. Is that what you all do? We are going to a park about 200 miles away this Sunday and want the correct presure.
TIA
"If it ain't broke, fix it 'til it is"
My Roadtrek
Tucson, AZ.
What size tires?
I run 63 front, and 78 rear on my 245/75R16E
Visit My Roadtrek
Handbasket
Asheville, NC
MP, the dealer's an ... idiot (kindest word I can think of). The sidewall is labelled something like "max load xxxx lbs at 80 psi". That's just the maximums for the _tire_, and says _nothing_ about your vehicle. Go with the RV maker.
BTW, I've tinkered with cars for about 40 years, and I've never heard of 'sidewall wear'... somebody's either blowin' smoke, or smokin' something.
Jim, "Drugs may lead nowhere, but at least it's the scenic route."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
MPSAN
Portland, Oregon
I will call LTV tomorrow and see what they say. I think I agree with you, Handbasket! However, both Les Schwab and Americas Tire told us the same at different times.
Also, these are 225/75 R16 LTX A/S Tires
past-MIdirector
Michigan
Well I have 19.5 and the manufacture label says 75 lbs on a MH P-30 frame, the replacement tires Max are 110 lbs and the rims are max at 95 lbs. So the tire shop set the new tire pressure to 90 lbs front and 95 lbs on the back duals. A lot of rigs have upgraded tires with heavier load range and require higher air pressure than what's on the vehicle label. Low pressure over time will damage tire sidewalls.
Chuck&Gail
In the Colorado Mountains
I don't have a Camping Van, but in all my vehicles I use the pressure recommended by the tire manufacturer for the ACTUAL MEASURED weight on the tire (using the highest pressure on a per axle basis). Works for me.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
ARcruiser
Benton, AR USA
I don't recall seeing anyone ever report needing that much pressure in the front.
I usually shoot for 55 to 65 in the front and 75 to 80 in the rear on all of my one ton chassis B's with load range E tires....
I woulda thought LTV would have a sticker in the door or somewhere's, as well as in the manual.
2 Big Cruisers, The Little Man, and Bailey / ARcruiser's Class B's (the first 8)
Rig #8 Under Construction! / Here's the Project Thread - I'm actually working on it again!
Hit The Road Jack
Treasure Coast of Florida
Problems caused by under inflation
Surveys by tire service engineers show that at least 25 per cent of all tires examined are under inflated by more than 10 per cent. Under inflation is one of the main reasons for rapid shoulder wear, uneven tread wear and premature tire failure. But take care; overinflation may also result in inferior handling, excessive tire wear and premature failure.
Source
2006 DIY Dodge Badged Sprinter Conversion
charles
Ohio
I run with 75# front and 80# rear, have done so in all three of my PW's, rides a tad rough on the pot holes, but handling is much better than a soft ride.
Nick
07 PW Excel TS
2011 Winnebago Vista 35F
2012 Ford Focus Tow
Blue Ox Aventa LX
Brake Buddy Classic
MPSAN
Portland, Oregon
Well, I called Michelin and they said that the Manufacturer should know the weight distro. So, if LTV said 62 in front and 79 in rear then THAT is what I should use! In NO case should the tires be filled to what is on the sidewall. Good info!
