RV.Net Open Roads Forum: Travel Trailers: Cool Mods - Thread restored 10/18/2012
 > Cool Mods - Thread restored 10/18/2012
Page of 200
pasusan
PA
Posted: 05/19/12 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
LTCLarry wrote:
pasusan wrote:
SkippysPad wrote:
Wow.....39 new posts since I last checked. Must be some neat Mods I need to see........NOPE.
And to think, I have to remind my kids how stupid they look when they have an argument on facebook for the whole world to see.
I've heard good things about the accumulator below. Never used it or tried it myself. Good Luck and let us know if you do it. Pics are always a good thing.
http://www.sportsmansguide.com/net/cb/shurflo174-24-oz-accumulator-tank.aspx?a=422840
Believe it or not the argument continues for the whole world to see...
Anyway - I added the accumulator - it works great. I especially like being able to flush the toilet if I forgot to turn on the pump.
Here's a pic:
Is this the Shurflo model from skippyspad?
Yes, it is - I got mine from Amazon. That's all I had room for.
Trip Pics
"Don't let the sound of your own wheels drive you crazy." JB & GF
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
SkippysPad
I'm not qualified to be a
Posted: 05/19/12 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it's the Shurflo. The advantage of this one is it's small. If you have room somewhere for the big one, that's great, but to put one on mine near the pump I would almost have to use the Shurflo. It's about the same size a my pump. Maybe about 1/2 the size of a 2 litre pop bottle.
2004 F-150 FX4 Super Crew, 5.4L, 3.73 Rear, Edge Evolution Programmer, Derale Fan Transmission Cooler, Prodigy Brake Control
Reese Dual Cam 1200/12K Trunnion Bars, 2011 Coachmen Freedom Express 295RLDS
1 kiddo, 3 dogs, Him & Her
welove2drive
Southwestern Illinois
Posted: 05/19/12 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
PennyPA wrote:
Where did you put these expansion tanks? Looks like the pictured one is in the house as opposed to the basement next to the pump. And what did you tap into? I don't see how this would alleviate the pump noise though since the pump would have to go on as you use the water in this tank, wouldn't it?
I have a travel trailer so mine had to be in the house as you put it. Just so happens its in the same cab. as my pump. Came right off the pump to the tank and then on to the rest of the water system. As others have said I set the tank pressure at or just below kick on pressure for the pump. I can run a faucet at full for 30 sec. before the pump comes on.
Dave and Marcia
02 Ford F350SD 4X4 SRW Longbed, 7.3PSD Auto
07 Flagstaff 829RGSS
Bit Bucket
Brookings, Oregon
Posted: 05/20/12 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
SabreCanuck wrote:
I added a 2 gallon tank that I purchased at Home Depot for about $50.00. I took the fittings off of the pressure side of my water pump and went to Home Depot with them in hand. I talked to the guy at HD about the fittings and found out they are somehwat 'special' but are the same thread/size as lawn sprinkler system fittings. I used a couple of steel braided water hoses (the ones that you might see UNDER your sink to tie the tank into the water system.
You CAN put the tank anywhere in the system but I am glad that I put it right beside the pump de to the SIGNIFICANT reduction in noise which I personally blame on 'rattling' water lines. The lines no longer rattle because the accumulator tank provides even pressure.
Well phooey, ain't got the room under there that I thought I had, gonna be interesting to see just what I can shoe-horn in there
...probably not going to get that one done before the trip this coming weekend...
On the other hand, I did get the generator re-installation finished up, really liking how it turned out.
LTCLarry
Maggie Valley, NC
Posted: 05/20/12 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Bit Bucket, very nice generator installation. How is the platform attched to the TT?
Bit Bucket
Brookings, Oregon
Posted: 05/20/12 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
The main support is a heavy guage 4" channel iron. It is welded to the frame with 3/8 x 4" flat bar extending 18" up the I-Beams. (4) 2"x2" square tubing pieces are supporting the box with webbing pieces added to re-inforce them.
I like the clean look so tried to hide the frame.
Fisherguy
Vancouver BC
Posted: 05/20/12 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
How much do you think all that weighs? Do you know how much it reduced your tongue wt by? Your genny a diesel?
06 Dodge Ram 3500 Cummins 6 spd std with a few goodies.
2007 Komfort 274TS, SteadyFast stabilizers, Trimetric 2025RV, PD9280, Honda EU2000i, Xantrex SW600, shocks and EZ-Flex suspension, Reese Strait-Line
Bit Bucket
Brookings, Oregon
Posted: 05/20/12 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
With a full tank (6 gal) of gas, 70 lbs of steel, 113 lbs of genny, and the battery and plywood and other stuff, it weighs right at 285 lbs.
On the tongue of the trailer, there is (4) 6 volt batteries, and under the bed in the front of the trailer near the batteries is a 2800 watt inverter.
Using my Shurline tongue scale before and after, I measured my tongue weight as increasing about 50 lbs (but it is hard to really tell because I get about +- 30 lbs readings on the shurline, depending on whether I am lifting or lowering the jack).
I can load the trailer in ways that easily add or subtract about 150 lbs from the tongue weight, which tells you how much beer and other unnecesary *stuff* we carry with us.
1ed
Northern California
Posted: 05/20/12 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
I got tired of the plastic strap for the cap of the water fill outlet breaking off all the time. So today I got a small piece of chain and put a cotter pin in the cap and attached the chain and the attached the chain to the outlet base. The cotter pin allows the cap to turn and now I will not need to replace for a long time.
Fisherguy
Vancouver BC
Posted: 05/20/12 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
Beer is never unnecessary!
Page of 200
