RV.Net Open Roads Forum: Beginning RVing: Water Pressure / Quiet Water Pump
RV.net
 > Water Pressure / Quiet Water Pump
tbear
Montgomery, AL
Posted: 04/05/02 03:21pm Link  |  Print  |  Notify Moderator
Our new MH has a basic Shurflo water pump that seems to work OK, but is a little noisy and does not provide great water pressure. Is there an upgrade you would recommend to improve water pressure as well as a little quieter?
Thanks for all of your help with my questions.
Mark
2002 Allegro Bus 40TP, 350 Cummins
wolfe10
Posted: 04/05/02 04:16pm Link  |  Print  |  Notify Moderator
Two separate questions. To quiet it down, make sure that the pump is not plumbed direct to hard plastic pipe. If it is, the pump sets the pipes vibrating. Most pump manufacturers recommend a 3' section of 1/2" reinforced clear PVC tubing which is FDA approved. It is strong but very flexible and keeps the pump from setting the pipes into motion. In many installations, all you need to get is a pair of 1/2" NPT to 1/2" hose barb fittings for the "house end" and from the pump maker 1/2" barb to pump and the hose. We did this on our coach, moving the pump about 3" and turning it around so we could run a loop of hose from the old hard plastic fittings to the pump. Cut noise in half.
If you do not have an accumulator, that will help maintain more constant pressure and additonally quiet the pump.
You can upgrade your pump to one with higher flow rate and possibly higher pressure, but the new pump will be quite a lot more expensive and draw more current. There is reference on this site to a new pump just out, but I am not familiar with it.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
bsinmich
Holland, MI
Posted: 04/05/02 05:44pm Link  |  Print  |  Notify Moderator
In addition to the water pipes you might find that the pump is attached directly to some piece of wood framing. There should be rubber mounting grommets there but I think they get thrown away because they take time to put in (7 seconds).
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
