RV.Net Open Roads Forum: Forum Technical Support: Recent Site Issues
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Recent Site Issues
Page of 24
pulsar
Lewisville, NC
Posted: 05/19/08 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
TXiceman wrote:
Both portals are running like a herd of turtle in a puddle so peanut butter. It is not my end, a T1 connection, and other sites run.....
Ken
Yes, I was having difficulty early today. When you say "both portals," to which two are you referring? Their are 8 portals.
Alternate "portals" to the RV.net Open Roads Forums
Tom
2oldman
WA
Posted: 05/25/08 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Couple problems today:
1. Rv.net: Mouse hover over title link creates large flashing window
2. Rv.net: Search results url links say 'Nothing found' .
both of the above work in goodsamclub
2oldman
WA
Posted: 06/09/08 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Forum must be slow lately.. I'm noticing a lot of duplicate posts.
Larry & Linda
Lansing MI/????
Posted: 06/15/08 07:56am Link  |  Quote  |  Print  |  Notify Moderator
I am getting the following coldfusion error at http://www.goodsamclub.com/cforum/index.cfm
on the beta site
any reason?
Error attempting to resolve the template "/glb/cfb/error.cfm".
The template could not be found.
The error occurred in D:\CFusion\CustomTags\CFBoards\CFB_Main.cfm: line 16
Called from D:\CFusion\CustomTags\CFBoards\CFB_Main.cfm: line 1
Called from D:\AGI Sites\gsc\boards\index.cfm: line 30
14 :
15 :
16 :
17 :
18 :
Please try the following:
* Check the ColdFusion documentation to verify that you are using the correct syntax.
* Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.8.1.14) Gecko/20080404 Firefox/2.0.0.14
Remote Address 24.11.171.57
Referrer
Date/Time 15-Jun-08 07:53 AM
Stack Trace
at cfCFB_Main2ecfm326724964._factor67(D:\CFusion\CustomTags\CFBoards\CFB_Main.cfm:16) at cfCFB_Main2ecfm326724964.runPage(D:\CFusion\CustomTags\CFBoards\CFB_Main.cfm:1) at cfindex2ecfm3413625.runPage(D:\AGI Sites\gsc\boards\index.cfm:30)
coldfusion.tagext.lang.ErrorTag$InvalidErrorTemplateException: Error attempting to resolve the template "/glb/cfb/error.cfm".
at coldfusion.tagext.lang.ErrorTag.doStartTag(ErrorTag.java:120)
at coldfusion.runtime.CfJspPage._emptyTag(CfJspPage.java:1876)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:147)
at coldfusion.filter.CFVariablesScopeFilter.invoke(CFVariablesScopeFilter.java:60)
at coldfusion.tagext.lang.ModuleTag.doStartTag(ModuleTag.java:256)
at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:1886)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:357)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:62)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:107)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:80)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:47)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:35)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:43)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.CfmServlet.service(CfmServlet.java:105)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at com.seefusion.Filter.doFilter(Filter.java:49)
at com.seefusion.SeeFusion.doFilter(SeeFusion.java:1494)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:249)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:192)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:318)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:426)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:264)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
goin2themountains
Aztec, NM
Posted: 06/27/08 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Don't know if the problem is with the Portal I use, or the forum, but when opening a thread, it takes me to the bottom of each page instead of the top. Mildly confusing to open a page and view a blank page (till you scroll up)
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
pulsar
Lewisville, NC
Posted: 06/27/08 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
What portal are you using?
I have never seen the problem you describe, even when clicking on the "Go to first new post" links.
Tom
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
goin2themountains
Aztec, NM
Posted: 06/28/08 07:36am Link  |  Quote  |  Print  |  Notify Moderator
I am entering through the TrailerLife Directory, which is also beta'ing a new format. Yes, I have checked whether I am set to go to the newest response, but wow, this takes me clear down into a white blank world I never knew existed.
goin2themountains
Aztec, NM
Posted: 06/29/08 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Gotta be the portal. Coming in through Goodsam doesn't act abnormally. I am thinking it's TLdirectory's beta.
pulsar
Lewisville, NC
Posted: 06/29/08 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
I just tried 5 different threads on TLDirectory and all opened properly.
I will post the problem in the Moderators Forum to see if anyone else is seeing a problem.
Tom
usndd
Albuquerque NM
Posted: 07/01/08 06:33am Link  |  Quote  |  Print  |  Notify Moderator
I cannot access through the GS portal. It's either the coldfusion error or "page not found 302" error. I've gotten it on this portal a few times also.
2007 V-6 Silverado, 2006 Santa Fe
Page of 24
