RV.Net Open Roads Forum: Class A Motorhomes: Workhorse antilock brake sensor
 > Workhorse antilock brake sensor
kokosfriend
Nashville, TN
Posted: 07/30/07 07:49am Link  |  Print  |  Notify Moderator
I just replaced one of the sensors a few months ago and now the antilock brake light is coming on intermittently again. Has anyone else had a problem with these on the workhorse chassis - 2002 Winnebago Adventurer? I feel this should not be happening.
Barb
kokosfriend
KD4AO
Punta Gorda, Fl., USA
Posted: 07/30/07 07:59am Link  |  Print  |  Notify Moderator
I had a similar problem several years ago on a Ford chassis. It turned out to be caused by the limited slip differential appearantly causing a wheel to skip when backing slowly and turning. The tough part was that the indicator didn't come on until later when I restarted the vehicle after being parked. The problem was diagnosed by a sharp mechanic who had seen something similar on a GM tow truck, he replaced the gear cluster and that fixed the problem. It was quite an irritation that lasted for over a year. Thank goodness for the warranty because it got very expensive by the time it was fixed. Good Luck. Bob
Bob
bnash
Tampa, FL
Posted: 07/30/07 10:18am Link  |  Print  |  Notify Moderator
Yes, I purchased my unit in 05 and have replaced two sensors in two years. I have a W22
2008 Damon Challenger 376
