RV.Net Open Roads Forum: 2004 Yukon XL, 5.3L, 3.73, tow in 3rd gear?
Search only in Tow Vehicles
 > 2004 Yukon XL, 5.3L, 3.73, tow in 3rd gear?
MIXONPHOTO
Tioga, La. USA
Posted: 08/13/07 09:26pm Link  |  Print  |  Notify Moderator
With the Yukon with the 5.3L towing a Jayflight BH, should I tow in towhaul and in 3rd gear or towhaul in drive? Seems like an awful lot of shifting in drive but occasionally I hit the right grade and the vehicle will stay in overdrive for a few miles.
The Mixon Family
2004 Jayco BH27
2004 GMC Yukon XL
polecatlarry
Full timers with NO home base..we like it that way
Posted: 08/13/07 10:12pm Link  |  Print  |  Notify Moderator
Leave it in 3rd...no difference in gas milage but a lot easier on the transmission. I have a similiar tow vehicle...5.3, 3.73 Silverado towing #7000 travel trailer.
lcbjack
Hot Springs,Arkansas
Posted: 08/13/07 10:57pm Link  |  Print  |  Notify Moderator
I tow in 3rd,better for my tran.
lcbjack
Cybergrunt
Cedar Rapids, Iowa
Posted: 08/14/07 05:11am Link  |  Print  |  Notify Moderator
Stay in 3rd with tow/haul mode on. That "awful lot of shifting" you mentioned will put a load of stress on your torque converter and heat up your tranny very quickly.
2001 Coachmen 248TB
5880 GVWR 3768 UVW 4980 GVW 650 Tongue weight
2003 GMC
5.3/3.73
13000 GCVWR 4932 curb 1468 cargo 6400 GVWR 7800 towing 6010 GVW 10340 GCVW
21 years USMC (Retired) (Op deployments: Honduras, Desert Storm, Iraqi Freedom)
SEMPER FI!
MIXONPHOTO
Tioga, La. USA
Posted: 08/15/07 03:33pm Link  |  Print  |  Notify Moderator
Thanks for the info.
rhondavid
Birmingham, Al
Posted: 08/16/07 06:05am Link  |  Print  |  Notify Moderator
When we were using a Suburban with your setup I towed in 3rd all the time with the tow/haul mode on. Main difference with tow haul is it changes the shift points of the transmission so once you are up and running it make no difference.
You do not want your transmission "hunting " for gears which it will do quite often if you drive in OD.
David,Wife,4 kids,SIL,1 grandchild
2003 Ford Excursion Eddie Bauer 7.3 PSD w/3.73 rear end
Jayco Kiwi Too 30T bunkhouse w/triple bunks
Prodigy Controller
Reese Dual Cam HP
Michelin LTX M/S
Topsail Hill Cult Member
