ssandpipe
NC
Valley makes a wiring harness that comes complete for the plug
in the bed with plenty of wire that plugs into back of
factory harness and allows both plugs one in the bed and
factory plug at bumper are both powered just drill
one hole in bed for plug with hole saw bit don't drill
to fast take your time, installed plug in the bed of
my 06 ram 3500 with the valley kit I got off ebay
for 20 bucks with shipping only took like 10 minutes
anyone can do it RV dealer price between 75-100 bucks
06 ram 3500 DRW
WGPuckett
Lexington, Ky, USA
hmmm... We didn't even consider it. When the hitch went in the new plug went in. They didn't charge us any more to put the plug in. So it must be so common for our installers they just include it in the price anyway. Ours is on the left just in from the tailgate.
Glenn & Becky Puckett
Lexington, Ky
2008 Fleetwood Bounder 35H
benb21601
Resident Expert
tgr2975 wrote: the same dealer who installed my pullrite superglide hitch install the outlet in my truck bed.
Ditto-all done FOC at the camper dealership. wouldnt be without one-kepps everything clean and put away, reduces the chance, of the wire getting pinched, or coming loose. As previously said-most new trucks have the wiring there already. all thats required is to plug it in, and drill the hole.
07.5 GMC Sierra 2500HD SLT-Crew Cab Short Box, LMM, SuperGlide, Prodigy
07.5 Jayco Eagle 345BHS-Trip Slide 5er, TrailAir Pinbox, Shocks, Aluminum Tripod, RotoChocks
04 Honda EM5000S Generator
Me,DW,DS,DD,DGSD
Our Picture Page
Joezilla
Mesquite, TX
MrT wrote: Got mine from tweetys.com, took about 30 minutes to install, no wiring required.......
Mine is on the way from eTrailer.com. What size hole saw do I need to install this?
Joezilla
2007 Ford F350 dually PSD 2WD King Ranch
2007 KZ Montego Bay 36 REB-3 38ft 11in. 5th Wheeler
TXBobcat
Fulltiming the USA
One suggestion. When you install the socket into the bed of the truck don’t do what most people do.. Even me. Install the socket in the bed in front of the drivers side wheel well. I had mine installed by the guy that installed the hitch and he put it behind the wheel well. I have to lean in over the tail gate under the 5er to plug it in. This way all you have to do is lock the hitch lever and plug in the pigtail for the 5er.
FWIW
BC
paztruck
San Diego, CA
I found one online and then called around to the local RV Trailer supply stores, found one that had it and about the same price as online. It was very easy to install. Hardest part was deciding where to drill the hole in my nice new truck.
2006 F250 Extended Cab, Long Bed, 6.0 PSD, Tow Package
2006 Keystone Springdale 242
tmb4971
upstate SC
Joezilla,
You'll need to use a 2 1/8" hole saw.
Tommy & Sherry
2002 F350 Lariat 4x4 Ext Cab 7.3 Diesel w/Edge Attitude/4" exhaust
2008 Jayco Designer 31RLTS
sickboy774
Los Angeles
TXBobcat wrote: One suggestion. When you install the socket into the bed of the truck don’t do what most people do.. Even me. Install the socket in the bed in front of the drivers side wheel well. I had mine installed by the guy that installed the hitch and he put it behind the wheel well. I have to lean in over the tail gate under the 5er to plug it in. This way all you have to do is lock the hitch lever and plug in the pigtail for the 5er.
FWIW
BC
I am glad I read your post TXBobcat. I was searching the posts for locations to install my plug. After reading your post it makes a lot of sense to install the plug forward of the wheel well.
Roy T
Dodge City, Kansas
I had the dealer put mine in the stake post inside the bed. They've had a lot of practice and did fast and wasn't that much.
boatdoc
South Coast Oregon
Not to be a smarta$$ but why do you need a plug inside the bed if you have one already below the bumper by the reciever hitch. When we got our first 5er, years ago, I was already to do the side mount wiring but then thought what the heck for??????? Thanks guys
2006 SD350 CC 4x4 TS
2009 Heartland Bighorn 3670RL
