RV.Net Open Roads Forum: Technology Corner: Remote temp alarm to your cellphone?
 > Remote temp alarm to your cellphone?
Big Katuna
Deland, FL
Posted: 08/29/07 09:10am Link  |  Print  |  Notify Moderator
I have been looking for a way to be notified if the inside temp of the motorhome goes up while we are away. We leave our dogs in the coach at football games with the genset running and always worry about it quitting. All the monitors I have found want a telelphone line to call you on. I found this one that is a USB solution for about $130. Plug your laptop into a inverter powered outlet and it will email your PDA-cellphone (which we have) when the temp goes over a programmable limit. Here is the link. LINK
My Kharma ran over my Dogma.
JSGrewal
Simi Valley, CA
Posted: 08/29/07 10:02am Link  |  Print  |  Notify Moderator
Its a great idea, but it seems expensive. I googled this real quick- seems like it could work, but may take some trial and error. I wouldnt mess with it when the doggies are on the line, but if you have time to play with it, who knows? Software is $39, sensor is $27 ( seems expensive for a thermister and cable though).
http://www.pcmeasure.com/index.php
2004 F350 4x4 Crew Cab PSD
2007 Weekend Warrior LE3505+6
MrWizard
Van Nuys, Ca
Posted: 08/29/07 11:47am Link  |  Print  |  Notify Moderator
$130 the engineering work has already been done !
how much do you value the life of your pets ?
how much to you trust the park 120v power on a 100 degree day, enough to be gone for several hours to be shopping, getting the car repaired ? to the movies ?
this lets you know, if the power fails and the temps go up inside the RV
this subject has come each summer, i believe there is hardware version that plugs directly into a cell phone, then calls what ever number is programed if the 120v power fails
so you know and can come back ,before the increased heat sets off a temperature alarm
Connected via Verizon Via LG VOYAGER VX10000
Maximum memory has been reached !
Chuck&Gail
In the Colorado Mountains
Posted: 08/29/07 03:40pm Link  |  Print  |  Notify Moderator
Actually $130, plus buy an inverter, plus buy a laptop, so more like $1000 I would guess. I have a cellphone, but not a PDA.
If someone knows of a REASONABLE price, I'm interested, but I think the above unit is way too expensive.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
96Bounder30E
Birthplace of the Boysenberry, Orange County, CA
Posted: 08/29/07 03:57pm Link  |  Print  |  Notify Moderator
Here is a page that I have favorited...........they have the model number.......SM-VM-500-3 for $232.00 http://www.safehomeproducts.com/SHP2/SM/HOME_GUARD.ASP
Not sure but, it may need to be powered by an inverter since it runs on 120vac..........a computer is not needed.......but, a second cell phone is......
Chuck&Gail
Posted: 08/29/07 04:18pm Link  |  Print  |  Notify Moderator
Above link looked real good until I read "Cell phone interface: Cell phone must interface with an analog adapter (same as interfaces with fax machine or computer). Figure on $700 plus." Oh well.
Chuck&Gail
Posted: 08/29/07 04:25pm Link  |  Print  |  Notify Moderator
Why not look at one made for RV's? This One runs off 12 volts, and just needs a cell phone. Also need a cell phone to answer I guess. Only about $500 (plus two cell phones).
Tech1
Georgia
Posted: 08/29/07 04:31pm Link  |  Print  |  Notify Moderator
What about an auto sensor that will cause your house batteries to run all of the fans in the coach? Not sure this would work, but it might. I too wonder about a way to notify me when and if the temp rises for my two Dachs.
96Bounder30E
Posted: 08/29/07 04:52pm Link  |  Print  |  Notify Moderator
This one might be a possibility too?
http://www.controlproductsonline.com
lesn8r
New Hampshire
Posted: 08/29/07 05:04pm Link  |  Print  |  Notify Moderator
how about webcam on a thermometer? Setup a simple website and check periodically?
just a thought
