RV.Net Open Roads Forum: Whats Your Real Weights? Truck and Trailer. The Real Deal
 > Whats Your Real Weights? Truck and Trailer. The Real Deal
Page of 61
BILLKINYON
FULLTIMER
Posted: 03/19/12 09:05am Link  |  Quote  |  Print  |  Notify Moderator
HI ALL
I have a paper to upload to the forum to show my weight on the truck and trailer. I just had it done at my sight. had each tire weighed and that way i know where i should shift my weight for better and more even traveling.
can someone tell me how to attach a document?
Bill
total weight is 25,000 on a 2010 cameo 36fws and a 2008 gmc one ton
Just Don
Longview Tx (EAST TEXAS)
Posted: 04/10/12 08:54am Link  |  Quote  |  Print  |  Notify Moderator
pritch272 wrote:
TV - 2000 Ford F250 SD Super Cab 7.3 PSD, real scaled weight with full fuel, hitch, DH-DW and misc. gear = 7,640lbs. TV GVWR is 8,800lbs
5ver – 2007 Keystone Laredo 29RL 32ft 9,160lbs loaded GVW. GVWR is 11,000lbs
Normal running TV & FW GCW weight= 16,800lbs, TV GCWR is 20,000lbs
Real Wet Pin Weight=1,820lbs
I have the same truck 2002, so all I should pull is 7640lbs. I'M looking at a Cameo and think it's out of my towing range, darn it.
IM looking to be a full timer and shouldnt bought the truck first, what I thought was a good deal with only 78000 miles seems like I made a mistake. Looking for a 37 to 40 in length.
If I posted this wrong please except my apologies and ILL stand in the corner. lol Don
Ford 2002 F250 7.3 diesel power stroke.
2008 NUWA HHII LS 32.5 FKSBG
lrash
Virginia
Posted: 04/11/12 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
On way home with new camper Montana 3625RE. All tanks empty Ford F-450 King Ranch 3/4 full fuel 2 people: Front axle = 5460 Rear axle = 7020 Total weight = 21,100
Dpopps
michigan
Posted: 04/12/12 10:50am Link  |  Quote  |  Print  |  Notify Moderator
On my way home from the dealer with the new camper I stopped at the scales. This weight is with a brand new empty unit, the truck has no gear and only a ¼ tank of fuel. I am guessing all loaded up and ready to go for a weekend I will be around 19,000lbs or a little less. If there is a scale somewhere on my way camping loaded up I might stop to check the loaded weight.
sirdrakejr
Las Vegas, Nevada
Posted: 04/12/12 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
What is the tow vehicle? If a 1T, it looks good to me.
Frank
livinglifegnd
NH
Posted: 04/18/12 06:05am Link  |  Quote  |  Print  |  Notify Moderator
hi guys am in the process of buying a 2008 Montana Mountaineer 345DBQ total dry weight is 11045 and payload is another 3265 hitch weight is 2310 according to specs wondering truck size I would need to purchase will be used why I am asking
DW-gray
Tulsa, OK -> Goshen, IN
Posted: 04/18/12 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Consider reading Before You Buy....
* This post was edited 08/12/12 02:55pm by DW-gray *
Dave & Amy
Fifth Wheel St. 13 Point Safety Report including -7 Point Safety Margin vs. Overload
Before You Buy That RV, Truck or Other Tow Vehicle
08 Dodge Ram 3500 4X4, Dually, 6.7L Diesel, 09 Heartland Cyclone 4012 with smart car in the garage.
cefloyd 1961
kentucky
Posted: 04/20/12 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Just took my f350 loaded full of fuel with my 40ft sandpiper loaded threw the cat scales here is what it said steer axle 4920 drive axle 5960 trailer 9180 gross weight 20060 is this a good weight for my truck?
2006 f350 superduty 6.0.. 2012 sandpiper 345RET loaded
Kenny3p0
Travelling Full Time
Posted: 04/20/12 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Here is my question, How are you determining your pin weight?
My reading was axel 1 4520 axel2 5940 axel 3 10520 gross 20980
05 ram 2500 drw 3.73 auto gcwr 21,000
09 keystone cougar 316qbs
2005 Ram 3500 DRW Quadzilla
2009 Keystone Cougar 316QBS
emaav
Oregon
Posted: 04/21/12 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
TV 1999 Chevy 3500 4 door 2wd DRW
Specs: GVWR 10,000
GAWR FRONT 4100
GAWR REAR 7500
Front Axle 3550
Rear Axle 4100
Truck Total w/5th Wheel 7650
5th Wheel
Specs. GVWR 4500
Front Axle 1650
Rear Axle 2200
5Th Wheel total 3850
Combined total 11,500
Me (Eli) 1972:
1999 Chevy 3500
1993 Shadow Cruiser 21F21RD
Page of 61
