RV.Net Open Roads Forum: Fifth-Wheels: What are you pulling
 > What are you pulling
Fish On I'll Get the Net
Dryden, Ontario, Canada
Posted: 09/13/07 10:32am Link  |  Print  |  Notify Moderator
What are you pulling with a 4.8L GM truck, 5th TT LB loaded.
Capt Skup
Southern Maryland/Nantucket
Posted: 09/13/07 10:37am Link  |  Print  |  Notify Moderator
5th TT LB loaded wrote:
Huh? 5th=fifth wheel, TT=travel trailer, LB=long bed, loaded=inebriated?
4.8ltr engine with probably an economy final drive gear set? Probably not too heavy of a trailer, under 4,000lbs.
Capt Skup
AD-1(AW)USN Ret.
Wonderful Wife, 3 beautiful Daughters
"Never get in a battle of wits with an unarmed man"
2008 F-450 Lariat 4x4
2008 Honda Odyssey EX-L
SunlineF281SR
SeaRay215EC
http://community.webshots.com/user/CaptSkup?vhost=community
cenley
NJ
Posted: 09/13/07 11:36am Link  |  Print  |  Notify Moderator
I had an 06 1500 4x4 Ext Cab 4.8 with the 3.42 gears when I first started looking at RV's. I was looking at Hybrids mostly but when I stepped up to the TT in my sig I knew I needed more truck.
Carl
04 X Limited V-10 3.73 Bilsteins,Timbrens,30mm Sway Bar,Reese Dual Cam
07 Rockwood 8317SS,Top Pop Rails Bike Rack, Champion C46540
Me, DW, DD, DD, and a Doberman
DobermanTalk.com
Posted: 09/13/07 11:47am Link  |  Print  |  Notify Moderator
Fish On I'll Get the Net wrote:
What are you pulling with a 4.8L GM truck, 3.73 gears, 5th wheel, travel trailer, and the weight loaded.
lc51willy
Fulltime USA
Posted: 09/13/07 01:09pm Link  |  Print  |  Notify Moderator
16,000lb 5er with MDT which wt. is 14,600
USA TRAVELER
LC&KC
MOJO (Deceased 4/10/06)
2000 International 4700 CREWCAB 530 power/Full Air ride cab.
JAKE BRAKE/ Gvwr 23,500
40ft. Prowler AX6 4 Slides/Trail Air Pin Box/HughesNet dish (
Cat320
Western AR
Posted: 09/13/07 01:11pm Link  |  Print  |  Notify Moderator
Nothing.
WNC-RV
Franklin, NC
Posted: 09/14/07 04:05pm Link  |  Print  |  Notify Moderator
See sig. Happy Camping!!!
Sam & Patti
2006 Silverado LT2 2500HD 4WD Crew Cab Duramax Diesel 6600 V8
with Allison 6 Speed Transmission
2005 Cedar Creek Silverback 29LRLBS Fifth Wheel
Reese 16K Kwik Slide Hitch/XM Radio/Directv/TomTom One XL GPS
Honda EU2000i Generator/Rotochoks
