RV.Net Open Roads Forum: Anyone Self-Installed Front Shocks on a Kodiak?
Open Roads Forum  >  Class C Motorhomes  >  Super C
 > Anyone Self-Installed Front Shocks on a Kodiak?
mfa
Posted: 09/19/07 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
I bought front and rear Bilstein shocks to have them installed on my 2005 Kodiak chassis. The rear shocks looked so easy to install that I did it myself with little effort this past weekend.
After studying the front-end for a while, I decided not to try doing the front shock myself for a couple of reasons --
1) On the left-side front shock, I couldn't figure out how one would unscrew the nut off the upper stem without the upper piston spinning. There seemed to be no way to grab anything to resist detorquing the nut.
2) On the right-side, the situation was even more complicated. There is no ready access to the upper stem. Seems to be some kind of housing built around it that covers it.
Has anyone here installed their own front shocks on a Kodiak that could give me some clues? Otherwise, I'll have to pay around $150 to get them installed...
ronfisherman
SE Michigan
Posted: 09/19/07 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a thread where I installed mine. Not very easy on the fronts. But a little patients will get it done. Another member also posted his experience with getting them installed in the same thread.
Saf-TTE tire monitor
erupert
Churchville, Maryland
Posted: 09/19/07 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
You need an impact gun to get the nut on and off. Not sure about the "cover" on the one side, but if you don't have an impact, you can't do the job.
'01 40' HRC Endeavor PBDD 330 Cummins
'97 Jeep Cherokee - Auction Special
mfa
Posted: 09/19/07 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks! After reading that, I may have the courage to take another look at it. My fronts came compressed and already have the "inner" bushings & washers on the shafts. The outer ones, including the nuts, came in a sealed bag. So maybe there is some hope for cutting the band and getting the ends in on the first try...
I also picked up on the tip about turning the wheel to gain better access. Don't know why that never even occurred to me!
mfa
Posted: 09/19/07 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
So, how does that work? Are you counting on the inertia of the shaft holding it back while the shock on the nut jerks it little-by-little?
erupert
Posted: 09/20/07 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Yep. That's how the shops do it all the time.
Gene in NE
Omaha
Posted: 09/20/07 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Here is a little used "tip", don't even try loosening the nuts on the front shock. Instead get a little longer breaker bar and overtighten the old existing shock and it will snap off.
2002 Trail-Lite Model 211-S w/5.7 Chevy
Gene
mfa
Posted: 09/20/07 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
That's an interesting approach.
I wonder, though, if it is possible that the threads on the shaft at the nut could strip and then the nut would spin but not back off over the good shaft threads that were sticking out from the nut to begin with.
MotherTucker
Atlanta, GA
Posted: 09/24/07 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
I just did recently did this, and got them off by using a large channel-lock pliers. There's a flattened "nut" there just on the top of the upper tube. It looks round at first glance, but 2 sides of it are actualy flattened, and I could grab and hold it with the channel-lock pliers. Then take the top nut off with a box wrench. If you had the proper size and (slim) thickness open end wrench, that would also work.
mt
asf#2
Kingwood,Tx
Posted: 09/24/07 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Your local auto supply store should have a shock removal tool for less than $10 that holds the shock stem while removing the nut. I have used it on auto shock replacement. Take your new shock into the store to be sure the tool will fit the "flat".
Jim
