vinny68
Bloomington, IL, USA
Is there such a thing as a smokeless campfire? If so, someone please school me on how to build one because I obviously can't do it. I'm not talking about those campfires in a can either. I want a real woodburning, crackling, popping, dancing flames fire with no smoke or at least a minimum of smoke. Is there such a thing?
vanman250
Indiana
You want a smokeless fire and I just want fire. I'm the worst fire builder ever. I have trouble getting fire starters to burn and thats the truth. Nobody can ever accuse me of arson. I always let the people were camping with start the fire and they have a rule, I can never touch the fire after they start it because it will go out. I will be following this one just to see if I can pick up a tip on building a fire. It's embarrassing to spend hours tying to get a fire starter to burn.
vanman250
kottfam6wi
South Central Wisconsin
The dryer hardwoods split into smaller pieces smoke a lot less. Burn wet pine and you are lighting a smoke bomb.
Joe
Our Family Pictures
Joe
Chris-9, Emily-5, Jessica-3, Jason-2
"Rallies Attended 9 1/2" (Wahoo!! we're catching up!)
2005 Dodge Ram 2500 Quad Cab 5.9L CTD
2005 K-Z Durango 315BH 5th Wheel (2nd Camper)
Mandalay Parr
Phoenix, AZ
The secret for no smoke is giving it plenty of air. Put the wood up on rocks with plenty of venilation or putting the wood like in a tee pee.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
602-321-8141
PopBeavers
San Jose, CA
Use wood that contains no water and no sap. Or as close to no water and no sap as you can get.
If you can find this on the ground, then you are obviously boondocking, because you likely will not find any well seasoned hard wood anywhere near a campground.
Wayne in San Jose
TV1:2002 Chevy 1500HD 4wd Crew Cab,Valley Odyssey brake ctlr,McKesh mirrors
TV2:2008 GMC 2500HD long bed 4wd Crew Cab,GMC brake ctlr,GMC mirrors
TT:Trailmanor 2720
Honda 2000
Yamaha WR250R,Polaris Sportsman 700 X2,Polaris Scrambler 500
runaground
Tracy, Ca.
Use dry (seasoned) wood, start with small pieces of wood and work up to larger pieces, not too much wood at once you will smother the fire, smoking wood is wood that needs more air flow to it or is too wet. Set across from the ugly people because smoke follows the ugly people
Larry / Cathy Hawkins
Pace Arrow 37C W24
AtlantaGuy
Atlanta, Georgia
Firewood arranged in a teepee where lots of air can get under it rarely smokes a lot and the extra draft caused by this arrangement typically keeps the smoke going straight up in the air and away from your face as well.
2003 Holiday Rambler Traveler 28RB
2005 Honda CRV
2 cats & a motorcycle
Skip and Norine
Fulltiming since Oct 2006
AtlantaGuy wrote: Firewood arranged in a teepee where lots of air can get under it rarely smokes a lot and the extra draft caused by this arrangement typically keeps the smoke going straight up in the air and away from your face as well.
Yep!
Either that, or just light a propane torch and set it in the middle of the fire ring ... viola! No smoke!
Traveling our country and seeing the sights, enjoying fun-filled days and campfire nights
See our travel pics
The rig: 2006 SportsCoach Cross Country SE
The toad: 2006 Saturn Vue
The Captain: Skip
The Co-Captain: Norine
Furry passengers: Penny & Biscuit
Sully2
Cincinnati
vinny68 wrote: Is there such a thing as a smokeless campfire? If so, someone please school me on how to build one because I obviously can't do it. I'm not talking about those campfires in a can either. I want a real woodburning, crackling, popping, dancing flames fire with no smoke or at least a minimum of smoke. Is there such a thing?
If ya REALLY want to get "trick"... ...try this stunt!
1) Make sure the wood is dry
2) Have the wood SPLIT into lengths no larger than 2" X 2" and the length ya need
3) Use a fire ring and have it elevated up off the ground a few inches
4) Find a 120V AC "muffin fan"
5) Some lengths ( 1 foot..even 2-1 ft long pieces) of 4" "stove pipe"
6) Squash one end of the stove pipe out of round to fit UNDER the edge of the elevated fire ring
7) Stick the "muffin fan" at the opposite end of the stove pipe and plug it into an electric outlet
What you end up with is a "mini blast furnace". NO SMOKE...PLENTY of "fire" ( You can turn the fan on and off as needed)
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Wherever I happen to park
I just got a 1 1/2 inch Muffin fan at the local electronics place
Got a 1 1/2 inch length of "heat riser pipe" This is a heavy foil tube that can take exhaust heat on a high power engine., is flexible and collapsible.
At the cold air intake end (Fan end) I sealed it with electrical tape. Fan runs on 12 volts, I have a LOT of 12 volts lying about.
