RV.Net Open Roads Forum: Folding Trailers: starting the furnace on a jayco 1207
 > starting the furnace on a jayco 1207
rmnpcolorado
Madison, WI
Posted: 09/23/07 07:02pm Link  |  Print  |  Notify Moderator
First, how old is the 1207? If it's old enough, it won't have electronic ignition, but that's doubtful.
Next question - did you give it a little while of running? It won't blow warm air immediately. But if you didn't hear the ignitor trying to light, then yeah, there might be some kind of issue there.
2003 Chevrolet TrailBlazer LT
2007 Jayco 1008
w/Carefree of Colorado SuperSport awning
crosbygroup
california
Posted: 09/23/07 09:07pm Link  |  Print  |  Notify Moderator
I had a 1997 Jayco 1207. You can't light it manually. Mine was temperamental it would not light unless both tanks were open. It would not run if the hot water heater was heating. We did take it to the shop and they replaced a thermocoupler, but that did not help either.
Crosbygroup 2008 Fleetwood Avalon Highlander
If you're not part of the solution, you're part of the precipitate. ~Henry J. Tillman
essie
Massachusetts
Posted: 09/24/07 05:48pm Link  |  Print  |  Notify Moderator
the pop up is a 1996. We didn't hear the ignitor sparking to light, so I guess it needs to go to the shop and have them look at it. Thanks to all who responded I appreciate your help.
Shredder
Santa Cruz CA USA
Posted: 09/25/07 01:10pm Link  |  Print  |  Notify Moderator
My 2005 Jayco 1006 has a auto igniter on the furnace. It will not light unless there is enough power in the battery to light it. Apparently it takes quite a bit of power as the fan will run, lights light, ect. On mine it was a pourly charged bad battery that did not let it light. With a new battery it lights just fine.......Shredder
He Ruide
Cincinnati Ohio
Posted: 09/25/07 03:37pm Link  |  Print  |  Notify Moderator
Scott, I had not thought of a poorly charged battery causing the problem. Thanks for that tip.
Fleetwood Evolution E3 - Yellow (DW let me get a Yellow one since she wanted an E3 with a slide out )
Hummer H2 - Black (DW vetoed the Yellow one, but I got two Yellow Hummer Folding Mountain bikes )
My Pics and Mods and My Weekly Blog
