RV.Net Open Roads Forum: Tech Issues: 6 volt Battery?
 > 6 volt Battery?
PrairieGoat
Colorado Springs, CO
Posted: 09/26/07 10:52pm Link  |  Print  |  Notify Moderator
Tarponteaser wrote:
If you swap out your 12 volt for a pair of 6 volts, do you have to fabricate a case/hold down for them...or is there something commercially available to facilitate securing on the camper?
If they are outside your rig (such as on the tongue) you have several options since they do not need to have an external venting system. I even found some nice ones in aluminum on some website.
If they are inside your rig (such as a 5er), your options will be much more limited. I ended up building a battery box setup.
Note that this just applies to flooded cell batteries. You can get away without external venting with AGM and Gel cell batteries, but the cost is significantly more.
Randy
2003 Chevrolet Silverado 2500HD D/A
2006 Wildcat 27RLWB 5er
 > 6 volt Battery?
