RV.Net Open Roads Forum: Towing a WW FS30 with a PSD F250
Search only in Toy Haulers
 > Towing a WW FS30 with a PSD F250
BigDogF250
San Diego
Posted: 09/24/07 05:34pm Link  |  Print  |  Notify Moderator
I'm using just about that exact combination and I would agree, go to a stronger hitch with 1700lb bars and tow it loaded before making changes to the suspension. You may decide to add the Timbrens, I have not because my truck only sags about 2.5" when the trailer is fully loaded and the weight dist. is on. It does not reach the additional leaf during normal load. I have the 1400lb WD bars and put a pretty good load on them. If you don't know how to adjust the hitch ask for help, it's not simple and the "tilt" can make a huge difference in the WD bars.
You will need at least 1 anti-sway control, I have never wanted more even when being buffeted by 30 mph gusts.
Use a tape measure when adjusting the weight distribution from the front and back bumpers to the ground, I was surprised at the impact that the correct settings had. I went from down in the back 6.5 up in the front 3 (this was the dealers setup) to down in the back 2.5 and down in the front 1 (my setup).
With the integrated braking system the trailer stops easily at the normal "boost" (5.0) on dry pavement but I do usually increase the bias to 5.5 in the rain, I don't want the trailer pushing me out of the way. This seems to provide just the right balance between the truck and trailer and helps remove the "white knuckles".
Congrats on the truck, I love mine (first diesel). Good luck with the trailer purchase.
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200 pulled by 05 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 05 Yamaha YFZ450 White/Red
94 Husqvarna WXC610, 2008 Polaris RZR 800
bugman696
Yuma, AZ
Posted: 09/24/07 06:06pm Link  |  Print  |  Notify Moderator
I have a 3018TT Raptor that I pull with an 04 250 FX4 PSD, and an 05 Duramax 2500 and have the weight distribution hitch and have had no problems at all pulling or stopping 12,500# I dont do much mountain climbing but when I have the tow/haul had no problems up or down...hope my $.02 helps
rod450
cal
Posted: 09/24/07 07:37pm Link  |  Print  |  Notify Moderator
Thank you all...........very helpful and informative.
Safety is first!!
Todster
Camarillo, CA USA
Posted: 09/24/07 08:24pm Link  |  Print  |  Notify Moderator
Definitely size up the hitch, other than that just choose wisely on your sway control.
2004 T34SP Sandpiper
2003 F-250 6.0
Donahoe Racing 8" spring lift with 37's and 4.33
2k/20k 90 deg. pullrite
1989 Lt500
2003 Warrior
2005 Yamoto 110
2004 Raptor 660
2007 Raptor 700R
http://community.webshots.com/user/tdztnka
Pullrite in action
kwlincoln
The Woodlands, TX
Posted: 09/24/07 09:40pm Link  |  Print  |  Notify Moderator
I'm surprised anyone would have a lot of sway with a 6 axle TH. For comparison sake to the original thread question, I towed my FS2600, full 40 gallons of fuel, full 150 gallons of fresh, Grizzly 660, Rhino 660, Grizzly 90, wife, dog, 2 kids, couple of guns and a bunch of******with my '06 F250 4X4 through steep mountains in the Ozarks in July. Did just fine. I didn't scale it, but I had to be to the max.
Broccoli1
Los Angeles
Posted: 09/24/07 10:46pm Link  |  Print  |  Notify Moderator
cause 1,2,3 axle don't matter with regards to sway.
You put the load at the tail and the tail gonna wag
06 F250 V10 SB 4x4 Gulp Gulp
WW FSC2800
Rincon 650, Rhino
Power Wheels 750
"Shoot, I'm the world's best backwards driver!"
jsalazar310
Carson, CA
Posted: 09/24/07 10:51pm Link  |  Print  |  Notify Moderator
+1
2004 GMC Sierra 2500HD 4x4 Duramax/Allison
2007 WW FSW2800 Billet Edi.
