RV.Net Open Roads Forum: Class C Motorhomes: Seneca tire pressure?
 > Seneca tire pressure?
BEVAR
Lake Worth, FL
Posted: 10/01/07 08:56pm Link  |  Print  |  Notify Moderator
Hi Guys,
We just upgraded our ride from an '06 Granite Ridge to an '06 Seneca 35GS. Does anyone have any clue to what I should run for tire pressure? I have been thru the forums and it does not seem to be addressed like it was for the E450.
Thanks,
Beave
regrus
Edmonton Alberta Canada
Posted: 10/01/07 09:58pm Link  |  Print  |  Notify Moderator
I run mine at 95 pounds front and rears. That's what the tag on the drivers door says.
2007 Jayco Seneca 34SS with Tracker Toad
ASA Glamis
Rancho Cucamonga, CA
Posted: 10/01/07 10:44pm Link  |  Print  |  Notify Moderator
You need to weigh it to find the proper inflation for the weight you are carrying. Then go to the tire manufactures web site and download the table showing the proper inflation for the weight that you have
2007 Jayco Seneca 35GS
parkmanaa
Houston, Tx.
Posted: 10/02/07 02:28pm Link  |  Print  |  Notify Moderator
ASA Glamis gives you the ONLY right answer.
No one can know exactly what YOU carry in your rig, therefore any
recommendation they make is purely a guess.
The major tire manufacturers' websites give excellent information
on tires, which includes a load/inflation pressure table that
gives you proper air pressure for YOUR rig. Of course they also
tells you proper procedure for weighing your rig.
