RV.Net Open Roads Forum: Truck Campers: Fastguns or Qwik-Loads
 > Fastguns or Qwik-Loads
WarrenS
Cypress, CA, USA
Posted: 10/08/07 08:23pm Link  |  Print  |  Notify Moderator
Let's clear things up.
FastGuns are the top of the line. No tools to adjust and they don't seem to rust.
Derringers and QuickLoads are pretty much the same thing except that the Derringers are powder coated and the QuickLoads have some other type of rust inhibiting surface. Both require using your original turnbuckle barrels and adjust the same was as you always have. Basically, they just replace the top hook on each turnbuckle.
The FastGuns are pricey but if you load and unload your camper they are well, well, well, well, well, well, well, worth the money.
Happy Trails,
- Warren
Wife, 6 year old boy, 4 year old girl
01 Lance 961 (9'6 with slide out). TorkLift Frame Moutned tie downs, FastGuns, SuperHitch
05 Chevy DRW,LB,CC,4x4,8.1L gas, Alison
78 Toyota FJ40 w/'97 350 Chevy & auto. trans.
87 Honda TRX250R
Wazzu
Camano Is, WA USA
Posted: 10/08/07 08:53pm Link  |  Print  |  Notify Moderator
Tork-Lift Fast guns for me.
2005 2500HD 4x4 CC D/A
2002 NL 9 1/2 Classic
2 goldens wazzu and Heide
Carol my camping buddy for life
iawia
Victoria, BC
Posted: 10/09/07 12:45am Link  |  Print  |  Notify Moderator
I have the quick loads. Probably would have got fastguns if I didn't already have the turnbuckles but these work just fine and are way better than just the turnbuckles alone.
iawia
97 Kodiak K99 on 95 GMC 2500HD 6.5TD
ramlinwillie
Littleton CO
Posted: 10/09/07 08:26am Link  |  Print  |  Notify Moderator
Qwikloads here for a couple years,I haven't had a problem with them, paid $99, guess the price is dropping.
04 F250 FX4 CC Lariat SB, Rhino Lining 6.0L V-8 Diesel 5-speed TorqShift® auto trans. Camper Package- Heavy Service Front Springs, Rear Stabilizer Bar,Auxiliary Springs, Rancho RS900X, Air-ride bags, Goodyear 245/70R19.5G, 04-Lance 821, Happijac Tiedowns.
DonCurley
La Sal, Utah
Posted: 10/09/07 12:43pm Link  |  Print  |  Notify Moderator
This is an interesting subject as I have wanted to move up to something better (or at least easier) over my Happijac turnbuckles. One of my concerns has been with the double nut set-up on the standard turnbuckles. Although I have been real careful (and lucky) so far, I can definitely see the potential for whacking my truck when trying to apply sufficient torque with two open-end wrenches to break the nuts free from one another (especially for the two front turnbuckles).
While I have heard a lot of good things about Fastguns (including in this thread), I have to admit I like the much lower cost of the Qwikloads. And since they seem to work OK (and are an improvement over the standard turnbuckles), I am likely going to go with Qwikloads.
-'07 Dodge 3500/QC/SB/SRW/4x4/6.7L CTD/6-spd auto/35" Toyo M/T's/Ride-Rite air bags/RS9000XL shocks
-'07 Apex 8 fully optioned w/220W solar/2 T-145's/2KW Prosine/Honda EU2000i/Tundra fridge/AC/etc
-'00 Jeep Wrangler TJ 4x4, highly modified w/5.9L Magnum V8
retired4fun
Colo
Posted: 10/09/07 05:06pm Link  |  Print  |  Notify Moderator
Had 'em both. Much prefer the Fast Guns. Sturdier, no wrenches to adjust, however, more money.
"03" GMC D/A
"04" Snowriver 9/6
"06" Bighorn 3055RL
"06" Polaris 800 EFI
"08" Polaris Ranger RZR
aka chopperbill
gregorya
Torrance, CA, USA
Posted: 10/09/07 09:06pm Link  |  Print  |  Notify Moderator
DonCurley wrote:
....One of my concerns has been with the double nut set-up on the standard turnbuckles .... see the potential for whacking my truck when trying to apply sufficient torque with two open-end wrenches to break the nuts free from one another.
Been there, done that, replaced the Happijack turnbuckles with the FastGuns.
I also had warranty issues with Happijack after lightly oiling the rear turnbuckles -- the rubber inside one failed. Happijack was going through a change of ownership, so the timing may have been poor.
But the best thing about the FastGuns -- no tools needed, period. Installation/Removal/Adjustments are quick and easy.
"I have never been lost, but I will admit to being confused for several weeks."
Daniel Boone
2006 Silverado LT 2500HD, 4WD, CC, SB, D/A
2006 Bigfoot 25C9.4
tycreek
Idaho
Posted: 10/09/07 09:38pm Link  |  Print  |  Notify Moderator
I find the wrench tails interesting ... I run my HJ's hand tight and have never had even a slight problem... That being said, mine HJ gear came with the TC, though my pre-purchase list had picked the TL line of tie-down accessories. Guess it will take me a few more years to find issue with the Qwik-Loads...
gregorya
Torrance, CA, USA
Posted: 10/10/07 12:52pm Link  |  Print  |  Notify Moderator
You need the wrenches for the jam nut.(opposite the index finger knuckle in the picture)
After the jam nut is loosened, you can easily adjust the barrel tension by hand. And then you cinch the jam nut back down to keep the barrel from turning and loosening.
All three of our campers have shifted a bit after a bumpy road/trail. Furthermore, I never took the time to mark which turnbuckle goes on which side, so I always end up adjusting them for the proper spring tension. It's just become part of my routine for loading and rest stop vehicle checks.
*ON EDIT* Added Happijac's picture
* This post was edited 10/10/07 01:02pm by gregorya *
gregorya
Torrance, CA, USA
Posted: 10/10/07 01:10pm Link  |  Print  |  Notify Moderator
Deleted double post
