scfan2
Murrieta, CA
My husband & I bought a new 31' Jayco TT and will now be upgrading our TV. We currently have a 2004 F-150 FX4 4x4 (only 14,000 miles & for sale)and are looking at a F-250 Lariat 4x4. Should we also look at the F-350? It's about $500 more. We're getting the V-10 since we'll only be using the truck for towing and won't be putting much mileage on it. GVWR of Jayco is 9000#.
Just want some input to make sure we buy smart.
2008 Ford F350 Lariat V10 4WD
2007 Jayco 31RKS
Mark Kovalsky
About 60 miles SW of Detroit
The F250 will be fine for that trailer.
Mark
2002 Ford E350 van connected to a 1998 SunnyBrook 33 FKDS travel trailer by a Hensley Arrow hitch
Former Ford Automatic Transmission Engineer, 1988-2007
Humpty
Clayton, NC
Mark Kovalsky wrote: The F250 will be fine for that trailer.
But the F-350 might be better for the next trailer if/when you go bigger.
I'd get the F-350
2007 Challenger 33DBB w/ Sidewinder
2002 Chevy 3500 CC DRW D/A
B&W Companion Hitch / Prodigy
TXiceman
(Near) Houston,TX
For the $$$ difference, I'd go ahead and get the F350....in case you ever want to go a bit heavier on a trailer.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
Smithroyal
Salt Lake City, Utah
Mark is right, the 250 will work. But then so would a 150 with springs and tires.
The 31' Jayco is not a small trailer.
Go test drive the 350.
Roy
Capt Skup
Southern Maryland/Nantucket
Check with your insurance company, compare rates for 250 and 350. Sometimes there can be quite a difference due to gross vehicle weight ratings. For your current needs the 250 will do a great job. If however you ever intend to go bigger or go to a fifth wheel, get a 350. Not much more money for quite a bit more carrying capacity.
Capt Skup
AD-1(AW)USN Ret.
Wonderful Wife, 3 beautiful Daughters
"Never get in a battle of wits with an unarmed man"
2008 F-450 Lariat 4x4
2008 Honda Odyssey EX-L
SunlineF281SR
SeaRay215EC
http://community.webshots.com/user/CaptSkup?vhost=community
scfan2
Murrieta, CA
Hadn't thought about the insurance cost; I'll call & check out. My big concern was maybe the F350 being too tall to fit into the garage but at 81" looks like we will be okay. Towing capacities for 250 & 350 are the same but payload is quite different.
Thanks for the input.
smkettner
scfan2 wrote: Should we also look at the F-350? It's about $500 more.
For $500 get the F350 for sure. You get a lot more payload rating on the F350 for that minor cost.
henw
F 350 is a lot stiffer. That stiffness will translate shock forces to your trailer that can cause structural damage over the years. If you don't need the extra carrying capacity get the F 250.
Check out www.airsafehitch.com.
Capt Skup
If you are contemplating buying the new models(2008)the F-350 rides just as nice as the F-250, matter of fact my 450 rides smoother/softer than my '04 F-250. If it were me, I would go for the F-350, but that is just me.
