RV.Net Open Roads Forum: Tow Vehicles: F-250 or F-350?
Search only in Tow Vehicles
 > F-250 or F-350?
bmanning
Phoenix, AZ
Posted: 10/10/07 10:40am Link  |  Print  |  Notify Moderator
Oh my dear God, here we go again...
If they are SRW trucks, they're the same truck... {****}
No reason not to buy an F350, but you will notice absolutely zero difference in ride, handling, performance, braking, etc. etc. etc.
If you find an F250 you like, buy it; if you find an F350 you like, buy it. There's no difference unless you're thinking of going to an F350 dually...
{****depending upon model year-- there are some very minor differences if you're thinking 05 or newer}
Honestly, if you'll feel better with a badge that says F350, that's what you should buy...just know that for most model years, an F250 is just as capable as an F350 SRW.
* This post was edited 10/10/07 10:46am by bmanning *
BManning
2002 F250SD,7.3L,4R100,4x4,crew cab/short bed,toreador red, Lariat, FX4,4" turbo-back exhaust,Edge Evolution,AutoMeters on the pillar,Michelin LTX M/S E-rated,3.73LS rear,camper pkg.,Garmin GPS,XM radio,CrimeStopper remote start/turbo timer/alarm
grampachet
West Coast
Posted: 10/10/07 10:43am Link  |  Print  |  Notify Moderator
My 250 King Ranch, CC, SB, SRW with 18" tires will not fit under the 6'6" (78") bar in the parking lot of the West Edmonton mall. (ouch) Did you mean your garage door or the truck was 81". The 350 would be taller than the 250.
Our 250 with the v-10 pulls our 28' 5ver very well.
Wish you well.
2004 F-250 KR,CC,SB,SRW,4x4,V-10,3.73
2008 Montana 3000RK
ib516
Up here!
Posted: 10/10/07 10:48am Link  |  Print  |  Notify Moderator
All else being equal, and only $500 more for the F350, I'd get the 350. The additional payload and rear spring would be nice to have. It may also have a higher resale value.
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen (still going)
Collision Reconstructionist
ScanGauge2
bmanning
Phoenix, AZ
Posted: 10/10/07 10:58am Link  |  Print  |  Notify Moderator
What he said...
scfan2
Murrieta, CA
Posted: 10/10/07 11:29am Link  |  Print  |  Notify Moderator
Wish you well.
The 350 is 81" according to the specs, our garage opening is 82". We test drove both last night and they rode pretty nice. We're looking at 2008's and ordering with only the options we use; so many seem to be overloaded. I'll think I'll go back to the dealer and measure the 350 on the lot. When I measured the 250 (even with 18" tires) it was about an 1" shorter than the Ford specs stated.
Thanks again.
2008 Ford F350 Lariat V10 4WD
2007 Jayco 31RKS
swebber
Brunswick , MD
Posted: 10/10/07 11:34am Link  |  Print  |  Notify Moderator
I agree with most of the above, get the 350. In the long run (future trailer)you will be much happier.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
TexasTH
Keller, TX
Posted: 10/10/07 11:45am Link  |  Print  |  Notify Moderator
Humpty wrote:
Mark Kovalsky wrote:
The F250 will be fine for that trailer.
But the F-350 might be better for the next trailer if/when you go bigger.
I'd get the F-350
F250's and F350's are the same truck. No payload difference unless you go with a DRW. So pick what you want.
Here is a link to towing capacities so you can see for yourself. 2007's and before actually have more 5th wheel towing capacity than '08's. If you look the only difference is when you go up to DRW like stated above.
http://www.fordvehicles.com/assets/pdf/towing/07RVTTgdeMay07.pdf
* This post was edited 10/10/07 11:58am by TexasTH *
2004 Weekend Warrior FB2200
2007 F250 Lariat PSD FX4 CC SRW
2007 CRF150RB; 88/140cc Race Pitbike
2003 KLX 110; 2005 CRF50
2007 E-Z-GO ST 2+2
Arcamper
Fayetteville, AR
Posted: 10/10/07 12:43pm Link  |  Print  |  Notify Moderator
Go with the F350. I wish I had because when you add crew cab, 4x4, diesel engine you eat up all the carry capacity of the truck. I was shocked to find the slide in camper certification on my truck was only 780 pounds on a 3/4 ton truck and the 5th wheel max weight could only be 10,300 pounds. The F350 in 2003 was the same truck except for 4 inch blocks on the rear instead of 2 inch blocks. The GVWR was 8800 on my truck but a 350 was 9800. It is worth the extra money to get a 350.
2007 Keystone Laredo 29RL 5th
2003 Ford F-250 SD Crew Cab 4x4 6.0 Diesel
Pullrite 16k Superglide with Super Rail kit
Brakesmart
cdrcos
St. Paul, MN
Posted: 10/10/07 12:52pm Link  |  Print  |  Notify Moderator
Not true - the difference in pin weight carrying capacity is significant.
Joe & Barb
2002 F-350,PSD,Crew Cab
2003 HH II LS 32.5 UKTG
*finally retired!*
bmanning
Phoenix, AZ
Posted: 10/10/07 12:58pm Link  |  Print  |  Notify Moderator
I agree, and as an F250 owner I've sometimes secretly wished my "2" was a "3", even though since I have the camper pkg it really is an F350 in disguise.
Besides, I like cab clearance lights, and you very, very rarely see them on a 250, but most 350s have them...
What I'd add, though, is that I consider my "true" GVW to be 9900lb, same as the 350; if you are not comfortable loading beyond 8800lb, that's certainly up to you, but in the real world you don't have "less truck" than a 350 owner.
A post like this one got chippy a few weeks back, and someone posted that Ford's TSB to deal with customer complaints about the 8800lb GVW of F250s was to re-badge them to make the customer more comfortable!
* This post was edited 10/10/07 01:54pm by bmanning *
 > F-250 or F-350?
