RV.Net Open Roads Forum: Tow Vehicles: F-250 or F-350?
Search only in Tow Vehicles
 > F-250 or F-350?
cdrcos
St. Paul, MN
Posted: 10/11/07 08:08am Link  |  Print  |  Notify Moderator
Arcamper wrote:
...The F350 in 2003 was the same truck except for 4 inch blocks on the rear instead of 2 inch blocks....
Again, not true. There is an additional leaf spring on the rear axle of the 350 which accounts for the capacity difference.
Joe & Barb
2002 F-350,PSD,Crew Cab
2003 HH II LS 32.5 UKTG
*finally retired!*
Arcamper
Fayetteville, AR
Posted: 10/11/07 09:19am Link  |  Print  |  Notify Moderator
My truck has the camper package so it has the exact same spring set up as a F350. The only difference was the overload spring and I have it. Again my truck rear end is just like a 350 with a 2 inch block instead of a 4 inch block.
2007 Keystone Laredo 29RL 5th
2003 Ford F-250 SD Crew Cab 4x4 6.0 Diesel
Pullrite 16k Superglide with Super Rail kit
Brakesmart
scfan2
Murrieta, CA
Posted: 10/11/07 10:55am Link  |  Print  |  Notify Moderator
Well thanks for all the good input although some of it was above me. We ordered the F350 last night after looking at specs and driving both. It was just about $500 more. Now just need to sell the F150 but we've got 12-16 weeks before the new truck arrives. Might have to cancel our Thanksgiving week at Kern River if we have no TV by then....again, thanks for all the opinions!
2008 Ford F350 Lariat V10 4WD
2007 Jayco 31RKS
dba2003
Akron, OH
Posted: 10/11/07 04:32pm Link  |  Print  |  Notify Moderator
There is a slightly larger diamater rear axle (rated higher) with one additional spline in the F-350.
olddesertrider
SoCal
Posted: 10/11/07 05:35pm Link  |  Print  |  Notify Moderator
Part numbers for rear axles for both the F250 & the F350 are the same. If you are referring to the ford vehicle specs it was determined there is a misprint in the specs in relation to the rear axle spline number and size of the SRW axles. They are the same for both models. This info. from a Ford parts dept. manager who posted on Ford-trucks.com last year.
olddr
ken burke
phoenixville, pa, usa
Posted: 10/12/07 12:47pm Link  |  Print  |  Notify Moderator
bmanning wrote:
ib516 wrote:
All else being equal, and only $500 more for the F350, I'd get the 350. The additional payload and rear spring would be nice to have. It may also have a higher resale value.
What he said...
For what it is worth, I agree with both.
ken
'06 Silverado, 3/4 ton, V8, 4.10 ratio, 4wd.
Sunline Solaris 286 TT (wet weight 7450#s).
Prodigy Controller, Reese Dual Cam Sway Control
"So many questions, so little time."
 > F-250 or F-350?
