RV.Net Open Roads Forum: Travel Trailers: LIFTED TRUCKS
Thumper_ehhhhh
Oakville Ont Canada
Posted: 10/17/07 08:42am Link  |  Quote  |  Print  |  Notify Moderator
This is when I wish I had a camera. Last year on our travels we pulled into a truckstop and there was a extreamly hi lift on a chev and he was towing a older terry. He made up a drop hitch oh at least 14" drop. The top of cab was level with the top of the trailer. looked funny as heck. I didnt see the driver to ask how it handles. I bet it is interesting though.
2005 Kodiak 25QB Hybrid
2001 Chev Astro
Husky Sway Control and Weight Distrubution
Map is camped in States and Provences only
Mods and pics http://community.webshots.com/user/Thumper_ehhhh
cdgm
Neptune, NJ
Posted: 10/17/07 10:18am Link  |  Quote  |  Print  |  Notify Moderator
I know nothing about lifting a truck, But I thought that a "Suspension lift" is putting on a new suspension, shocks tires etc and a "Body lift" is just adding spacers between the frame and the body.
I would think both would affect your center of gravity based on what you did.
I also would think if you do a "Body lift" it would NOT change any of your towing ability because all you did is lift the body from the frame and not change any of the suspension or drive train.
Can anyone clarify this?
2007 Max Lite ML28 RS
1999 Ford E 350 Super Duty 15 Passenger Ext Van
6.8L V10 / 3.73 Gears
Yel=States I have camped w/ the family
Grn=States I have slept in but not camped
Red=States I have visted or passed through
skinnerr
IL
Posted: 10/17/07 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
On a normal “body Lift” the angle of the drive shaft changes somewhat due to larger tires to go along with the look. You will also change the center of gravity due to the weight of the cab being moved up.
* This post was edited 10/17/07 01:04pm by skinnerr *
*Chevy K1500 Z71 w/TP
5.3L SB 3.73AR 8,100lb TL
*Chevy TrailBlazer
4.2L
*KZ Coyote160-2007
Equal-i-zer Hitch
Tekonsha Prodigy brake controler
wrenchbender
Phx
Posted: 10/17/07 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 01 Duramax, I tow a 12k boat, when I had a 2" lift it made the tow hairy in a crosswind condition. I was continually crabbing. Went back to stock and it was much more stable.It is a4x4.
LeeShearer
Royersford, PA
Posted: 10/17/07 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Larger tires will not change the driveshaft angle.
2005 Fleetwood Resort EXT 25SB
1999 Chevy K3500 short bed dually
DA INFERNO
Fresno Ca
Posted: 10/18/07 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
en3chix wrote:
If you are going to lift your truck and put bigger tires on it, do yourself a favor and change the gear's in the front and rear end. Any good off road shop can do the math and tell you what gear ratio you need to get back to "stock". What I mean is tranny ratio, rear end ratios and tire ratios are combined at the facoty to give you a 1 to 1 ratio, etc. If you put biger tires you change the ratios (1 to 1 1/2, etc). Changing the gears will put it back to stock.
yes, mine should be at 4.27 but I wanted for better towing and in the sand. I went with 4.56s
06 LBZ 2500HD W/ 8" NCT LIFT AND A LOT OF EXTRAS
07 3305 WEEKEND WARRIOR
08 Polaris RZR
LTZ 250
PREDATOR 90
SCRAMBLER
TRUCK PICTURES
SOME TRAILER PICTURES
abuen
victorville ca
Posted: 02/06/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
just to let you guys know i own an 05 silverado 2500hd diesel. ive got a 12 inch cognito lift kit. 40in tires regeared rear end to 4.88 and tows 8000 lbs beautiful. i just put the banks pda system in it. recommend it smokes tires.
BurbMan
Long Island, NY
Posted: 02/06/08 07:25am Link  |  Quote  |  Print  |  Notify Moderator
You don't need a lift kit to tow in the sand, just some good AT tires at 12 psi or so. Do you put a lift kit in the TT too? Noooo, just air the TT down also...
That small body of water would be the Atlantic Ocean.
dodge guy
Chicago, western subs.
Posted: 02/06/08 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Wow! 3 pages and only 2 people mention the important part about the lift! gears. obviously if your going with a lift your going to bigger tires. and if you do go with a lift make sure the lift springs are rated for the same weight as the factory springs! a slightly larger offset wheel will make up for most of the higher center of gravity.
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
birddog84
Brookhaven MS
Posted: 02/06/08 09:08am Link  |  Quote  |  Print  |  Notify Moderator
If you put a lift kit, say 8" or more on a tow vehicle, then had an accident pulling your trailer (or not), the other vehicle is damaged and occupants injured, and it's your fault, does the insurance company bail on you and leave you exposed to loose what cash and equity in investments you may have because you wanted a cool truck? Does your insurance policy have a clause where the policy becomes null and void in the event you "alter any factory designed engine, suspension, frame, etc. components"? I'm not stating this would always be the case. However, I was in the tire and truck accessory business for a few years, and we got out of the business of installing lifts because of this. My garage coverage underwriter pointed it out to me. I didn't want to be another pocket a trial lawyer could dig into. BTW, I've lifted three of my personal vehicles, so I'm not knocking lifts, just wanted to offer my two cents.
