biggrigg
NC
Just thought that I would give an update from this old post. http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/20210338.cfm
I will probably mess the link up. I bought a new Reese dual cam and installed it. Checked the clearances and all that good stuff. I am taking the bars off at the bottom of my driveway and so far it is working well. We have been on several trips and have had no bends or anything unusual. I am hoping that it really was my driveway causing trouble. I appreciate the help from you guys.
2011 Sabre 30BHDS
00 Excursion 7.3 PSD
skipnchar
Topeka or somewhere else
Yep...you messed up the link
I had a similar problem turning into a restaurant in Va. while on our 60 day trip. My spring bar broke in half near the cam end. Good luck / Skip
StevenBigBear
Palm Springs California
shouldagotahensley
Ford Excursion 4WD - V-10
Hensley Arrow - Prodigy - Landyot Radius-Rod - Helwig Rear Antisway Bar - Bilstein Shocks - AirBags
2008 Jayco Eagle 320 RLDS
320 RLDS JAYCO EAGLE
WA6ARC
Keith99RS
Suffield, CT
StevenBigBear wrote: shouldagotahensley
Buy me one and ship it to me and I gladly will. Otherwise I will keep the money I saved and put it in my IRA while happily using the Reese DC that has perform flawlessly for 2 years. Why is it so difficult to believe another product performs well. The Hensley is not without it's faults either BTW.
Smoke 05 Titan SE CC 4X4
K&N panel filter
PRG 2.5" Leveling kit
Bilstein front,Icon rear shocks
Powerstop slotted rotors
18" Wrangler AT/S LT's
2009 Fleetwood Prowler 2702BS
Primus Brake Controller
Reese DC w/ 1,000lb/10,000lb WD
dodge guy
Bartlett IL
And how would this have helped his problem? as far as I know a HA is mechanical as well!
Some of you guys really crack me up!
Wife Kim
Son Brandon 10yrs
Daughter Marissa 9yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear Hellwig sway bar
Reese HP dualcam,Prodigy brake controller.
A bad day of camping is
QCMan
Lawn Guy Land, New Yawk
Biggrigg, remember that some free advice is worth exactly what you paid for it.
2004 Starcraft Aruba 25RS, 2004 Dodge Dakota SLT extended cab. Just the two of us, 2 Jacks and a desire to roam!
WV Camper
Salem, WV
StevenBigBear wrote: shouldagotahensley And you guys wonder why many of us get tired of your arrogance about a trailer hitch of all things. You all either need to find a way to make yourselves feel better about spending that kind of money on a hitch or get over the fact that most people aren't impressed with your "need" to have the "best, safest, nothings too good for my family, etc,etc.".
Mike
Mike , Elissa, Daisy the Mutt, and Delilah the camp dog 2007 Rockwood 8280SS
downtheroad
Pacific Northwest
Oh Brother.. you don't need to justify your $3000 to anyone out here. Just TRY to get comfortable with your decision and stop trying to convince the rest of us that you did the right thing.
I've come to believe that if I posted that my hitch had a chip of paint fall off someone would tell me that I "shouldagotahensley."
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort .... Our Rig Picture>>Click.
Reese Dual Cam HP
Angelo.S
Onatrio ,Canada
I am curently towing with GMC Envoy 2W drive pulling a trail cruiser about 4000 lbs loaded with an equalizer hitch and find that I can not get enough sway control with it if I raise the supports on the trailer I get more control but the bars are not pararlel to the frame is this normal and any feed back on this hicth would be appriciated
Thanks
Angelo
WV Camper
Salem, WV
I believe you need to adjust such that the TV and TT are level. That should put enough pressure on the bars to provide sway control. Also, you want to check to see that the bolts (where the bars connect to the hitch) are tightened properly.
Good luck
