RV.Net Open Roads Forum: Hybrid Travel Trailers: Jayco 23B and Tornado
Open Roads Forum  >  Hybrid Travel Trailers
 > Jayco 23B and Tornado
sing4mom
Georgia
Posted: 10/13/07 01:31pm Link  |  Print  |  Notify Moderator
Can anyone give me some hints about mounting the Tornado on the 23B? It says to mount directly across from the outlet...but we can't because of the angle of the tank...can anyone help?
thanks
bdhoun
Waterdown, Ontario
Posted: 10/13/07 02:31pm Link  |  Print  |  Notify Moderator
My Jayco 232 has the same tank and the same problem. I mounted my Tornado beside the level sensors on the same side as the tank drain. Not the optimal position by the couple times I used it I thought it work quite well.
'06 Ford F-150 flareside crew, 5.4l, 3.55's
'07 Jayco 232
prodigy and Equal-i-zer
Sparkie 2
Aurora Ontario Canada
Posted: 10/13/07 05:35pm Link  |  Print  |  Notify Moderator
I posted the same question and received various answers. One thing that was constant, was that there was not enough space on the angled slope to mount the Tornado unit.( The recommended location) Nor was the angled adapter enough to hold the Tornado sprayer level. I mounted it on the forward side of the black tank. Just left (passenger side) of the drain pipe. I then ran the clean rinse water tubing in the adjacent "Z" floor support. With this mounting, it seems to work well for us. I hope this helps.
David
2007 Chevrolet Avalanche LTZ
2006 Jayco Jay Feather 232
mmpmmcdonald
Rochester, NY
Posted: 10/14/07 05:19pm Link  |  Print  |  Notify Moderator
I have a 23B, and mounted the "Quickie Flush" (similar to the Tornado) to the tank. I struggled with the position as well,and ended up putting it several inches back from the sensors, and a little higher than the instructions called for. It seems to work terrific. I also found it extremely helpful to buy a clear elbow to the waste hose in order to see when the water ran clear. No more guessing (and I am pretty uptight about these things.
Good luck with yours!
Mike
4 Daughters and a Wife
Jayco 23B (2006)
Yukon XL (2003)
Hector Bravo
New Jersey
Posted: 10/14/07 05:25pm Link  |  Print  |  Notify Moderator
I put my flush device, it wasn't the Tornado, right through the oblong hole in the frame rail on the same side as the drain. I don't think my flush unit has as good a flow as the Tornado but it works great there. I consider it to be the best addition I have made to my 23b.
Hector
The Bravos
2006 Jay Feather 23 B
2006 Titan Crew Cab
laramies
Glenmont, NY
Posted: 10/15/07 07:43am Link  |  Print  |  Notify Moderator
I have the Jayco 232, which has the same angled tank, and I mounted the Tornado across from the drain. If you search this forum for tornado and 232 another user, I think Ranger431, posted some pictures for me of his mounted opposite the drain back in April or May. With those as a guide I did the same, the Tornado does point up slightly but it does work fine.
Jim, Harleen, Jimmy (14), Joshua (11) and Jessica (9)
2007 Jayco 232
2006 Dodge RAM 1500 4x4
Prodigy Brake Controller & Equalizer
Ranger431
Murfreesboro, TN
Posted: 10/17/07 01:35pm Link  |  Print  |  Notify Moderator
Here are the pictures - there was a "wedge" adpater that came with my set. It's been on for a whole season, and used alot and works great.
2006 Jayco 232
2004 Nissan Armada LE
CamperMan07
Hartford, WI
Posted: 10/19/07 06:34am Link  |  Print  |  Notify Moderator
I mounted my Tornado across from the drain on the angle section on my Jayco 19h. It works great.
Todd
2006 Ford Explorer
2007 Jayco Jay Feather EXP 19H
My Pics
