TAFSTER
PEMBROKE PINES, FLORIDA
is anyone having the problem of the trailer jerking during slow speed stops?
it feels like the trailer brakes are releasing just after the truck brakes and causing a jerk.
has anyone found the correction for this problem?
BarneyS
S.E. Lower Michigan
That is not just a problem with Dodge truck, it is a problem with all trucks if you have certain cheap controllers. I solved the problem by purchasing a Prodigy. There are other good brake controllers that will give you smooth stops also.
I am sure many others will be here shortly to talk about their Jordon, Brakesmart, TruControl, or other controllers.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
skipnchar
Topeka Kansas USA
Barney is probably correct but I HAVE seen a few posts from Dodge owners that talk about a delay in the brake lights going off which could cause a delay in releasing brakes on the trailer. Good luck / skip
Turbo Diesel Dude
Green Mountain, NC
Have a Tonkesha(?) on my 2005 2500 Ram and never a problem except when I don't pay attention to the adjustment.
charles weidman
VanRedmond
Jacksonville, FL
I have a 2006 Dodge Ram 1500. I use a Prodigy brake controller. Ever since setting it up the first time, it has been nothing but smooth. Even backing up works smoothly.
Good Luck
Chris and Jimmy
Greentow
Dover, DE 19904
Have the prodigy in mine (almost 3 years and 20K towing). No problems at all. Have to readjust when towin SIL's utility trailer, but other than that, Good To Go.
Lee
2004.5 Dodge 3500 DRW QC, 4x4 LB, CTD 600 ,auto,4.10 , Prodigy, 05 Cedar Creek 36 RLTS w/ lots of bells & whistles .Honda 3000 genset. Mrs Greentow & Missy, Shih Tzu with an attitude. USA(R). 30+ years in the Fire/EMS service. CCRVC #29, GS Life member
Ray,IN
IN, USA
I think I answered this on another forum. First adjust your trailer brakes. Now try re-adjusting your controller exactly according to the instructions. It sounds like yours is set-up too agressive.
foneguy493
northeast ohio
mine is a techshona, on an 04 dodge 1500 4x4 quad, i have mine a little agressive but when i let off the brakes no bouncing
sounds to me you either have a goofy controller or that funny leveling dial on the controller may need adjusting like the others stated.
ive used this controller on my 99 2500 and on 4 trailers now.
take pictures.....leave bubbles.....lets go diving
places weve been
04 1500 ram 4x4
08 hornet 27b hideout
97Vortec
Idaho
I have a cheapy...I just keep dialing it in little at a time until I am satisfied. Good Luck!
cec311311
N. Carolina
I use a prodigy and have never had this problem. I can't say enough good things about the prodigy controller!
2007 Dutchmen 29QG-S
2003 Dodge 2500 Quad Cab 4x4 5.7 "Hemi"
Equalizer and a Prodigy
