RV.Net Open Roads Forum: Tech Issues: Foul odor from hot water tank?
 > Foul odor from hot water tank?
luvlabs
Frederick, MD
Posted: 10/14/07 06:51am Link  |  Quote  |  Print  |  Notify Moderator
The easiest way to deal with this mess is to simply drain the water heater between trips. No water, no bacteria, no smell. Zenfookpower's statements are particulary true for Michigan water which is heavily contaminated with iron in many parts of the state. What you are really producing is iron sulfide from the action of the anode - whether you have bacteria present or not.
Carriage Cameo 33CKQ | 08 GMC 3500HD CC LB Duramax Dually | Sam the Cat and the Labs | Best wife going
gon2dadawgs
I'm here X
Posted: 10/14/07 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I "picked up" some BAD water in AZ a couple years ago. Anode did not help. It was on this forum that somebody told me to pull the plug the WH tank and put as much vinegar as possible in the tank, fill the rest with water, leave it in there for 24 hours.
The next day you hook up to city water, run all faucets and the potty and everything is great. I used approx 4 gallons of vinegar, cheap at Smart & Final.
In reading about this rotten egg smell I found it is due to a chemical reaction between the aluminum tank and the sulfer.
Home is where you unhitch
wolfe10
Posted: 10/14/07 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Again, we are getting posts about two VERY different water heaters.
Suburbans have steel tanks and use an anode.
Atwoods have aluminum tanks and do NOT use an anode.
PLEASE, read the owner's manual on YOUR water heater and follow their advice.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
john b
anywhere USA!
Posted: 10/14/07 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Atwood with no anode rod and when ever we go to the upper peninsula of Mi on the eastern end we get rotten eggs out of it. Atwood tells how to flush it to stop it for a while. Not real hard to do! gontodadogs is on the right track!
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2004 Crossroads Paradise Point PF33Rl 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
RKW
Four Corners, New Mexico
Posted: 10/15/07 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
HERE is more than you ever wanted to know about rotten egg smells and anode rods.
Ryan
  • 2007 GMC Sierra Classic
  • 1994 Salem 24RK
  • Dual Honda EU2000i Generators
    The wages of sin are death; but after they're done taking out taxes, it's just a tired feeling.
  • lenain
    California
    Posted: 01/05/08 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
    This string is several months old, so maybe nobody who SHOULD see this WILL see this, but there were issues I thought it important to address.
    I ran across the string while doing what I call a "plagiarism search," looking for folks who have appropriated parts of my Web site. I run a site and forum devoted to water heater maintenance. I am not going to name it, in order to comply with the "noncommercial" rule for rv.net, and I signed up with a Yahoo e-address for the same reason, since my other e-addresses contain my Web site address. I've had a bellyful with idiots trying to advertise in my forum, so I'm right with you there!
    ZenFookPower's second sentence was what brought me here, as it is taken verbatim from my site. It's not quite on the par of putting it into a commercial Web site, but hey, that's still naughty, mon ami.
    As to what brought me back, it's this: Any water heater will develop odor problems if it sits long enough. If that is all there is to it, then a couple of pints of hydrogen peroxide poured into the tank will fix it.
    If the smell is recurring, though, it usually means there are anaerobic bacteria in the water that react with the aluminum and magnesium sacrificial anode rods that come with all glass-lined steel water heaters. The solution is an aluminum/zinc anode if you don't soften your water (and I expect that's all RV owners!) and a powered anode if you do.
    A couple of people suggested removing the anode, and one said the only reason it is even there is because the companies have always done it that way.
    So you should know that removing an anode always voids the warranty. For good reason. I have serviced thousands of residential and commercial water heaters and if you had seen what was left of a lot of the anodes, you would not think they were there just for the heck of it.
    Further, the manufacturers are extremely price-sensitive. I once tried to get a company to include a brass ball valve to enable sediment buildup to be flushed and it wouldn't do it because that would be a few dollars more that it was spending than its competitors. Since anodes cost more than a few dollars, if they could get rid of them, they would.
    Anodes are there for a reason. They react with a small amount of exposed steel inside the tank and protect it and when they are consumed (or removed), the tank eventually rusts out.
    Randy Schuyler
    Steak2k1
    Calgary, Alberta
    Posted: 01/06/08 12:30am Link  |  Quote  |  Print  |  Notify Moderator
    Randy is right on the money here guys..
    Basically the reason that they are there is this. H20 (water w/some salts in it) + Fe (Iron) + heat = a corrosion cell (actually a battery of sorts with electrons moving from one to the other), and results in corrosion of the interior of the heater (rust).
    In a water tank (same as the one in your home), one of the materials is the cathode and the other is the anode (tank wall). Without a "sacrificial" anode the tank would likely rust out in a couple of seasons or quicker even.! So taking it out is not a good thing to do.
    If you take out your anode while winterizing your trailer (I do in order to drain the tank), you will notice that it starts to look corroded and that is exactly what is happening...better it than the inside of your hot water tank.
    I have had my anode in since new and it will go on it's 3rd and last yr. as I will replace it next time I winterize.
    rgds,
    stk
    Teresa-Meagan-Kaylee
    '06 GMC DMax CCSB w/a lil 'Xtra Jam
    2006KZ KY-Yachty CT22 done comfy.!
    Reese 750WD w/DualCam Sway: 50W Solar
    Std. Mods & Aluminum Rear Bumper Storage Solutions
    http://community.webshots.com/user/steak2k1
