RV.Net Open Roads Forum: Tow Vehicles: Wiggle, wag, flexomatic frame Toyota
Search only in Tow Vehicles
 > Wiggle, wag, flexomatic frame Toyota
Page of 10
Daniel C.
San Antonio, Tx USA
Posted: 11/27/07 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
I am embarrassed to admit that I was delighted with the way my Toyota towed my 8500lb trailer over the weekend into the Texas Hill country. I should have read these posts first so I would realize that it was an allusion that I had virtually no sway, stunning acceleration, quiet driving (mostly at about 2-2500 rpm), much more driving comfort and confidence than my old 1500HD chevy, and 9.5 mpg towing about 65 mph with no difference in feeling of confidence when driving momentarily at 70-75 mph. Now I am afraid to drive the truck, because I was obviously hallucinating and was actually in great danger. Please pass the Risperdol!
Dan
Dan
2002 Trail Lite 211S; 8.1 Liter Chevy,
2007 Tundra Double Cab 4X4 - Hot Rod,
2005 30RLS Outback Sydney Edition,
2007 Jeep Compass
Allen Schultz
Divide, Colorado USA
Posted: 11/27/07 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
It would be interesting to see which truck in that video has the best off road traction where keeping four wheels on the ground is important. People don't always buy a truck to tow with. Off road capabilities are also important.
I think Ford probably chose the speed at which the Toyota appeared to be the worst. At different speeds the Ford and Chevy would likely have behaved in a similar manner.
RV net members could conduct a static test by jacking up one rear wheel until the opposite side tire comes off the ground, and then photograph from behind.
02 K2500HD Crew Cab Duramax Long Bed. Rickson 19.5" wheels + Bridgestone R250's. Rancho 9000's, Hellwig Sway Bar & Leveling Springs. 02 Summerwind 8.5 Camper with extended cabover. Honda EU3000 runs 13,500 AC.
Charlie D.
Gonzales, La.
Posted: 11/28/07 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Met a guy Monday who said Toyota is buying his truck and $700. bed cover back. He was pulled off the road by a Louisiana state trooper because his front wheels were bouncing off the road. He contended that it was harmonics set up between the truck and trailer. Toyota sent engineers from California and Texas and said it was not possible because they had spent a BILLION dollars developing the truck. After driving his short bed AND a long bed, both problems developed with them and has now determined that it is a result of harmonics. He loves the truck but can not tow with it. Don't shoot this messenger, I am just repeating information a total stranger and owner volunteered.
Enjoying Your Freedom?
Thank A Veteran
2007 Holiday Rambler 32SKT
2006 Chev LT D/A CC
Allen Schultz
Posted: 11/28/07 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
I won't shoot the messenger, but I think asking for authenticating information is within reason.
Charlie D.
Gonzales, La.
Posted: 11/28/07 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
I'll see if he will give me a notarized statement or a copy of the check.
Keith99RS
Suffield, CT
Posted: 11/28/07 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Have you been drinking? Seriously. This post makes no sense. How do harmonics cause the front wheels to bounce off the road? Perhaps way too much tongue weight and no WD could do it but use your head. FWIW if this was a full line problem the NHTSA would be involved and there would be a recall. Take your idiotic trolling elsewhere.
Smoke 05 Titan SE CC 4X4
K&N panel filter
PRG 2.5" Leveling kit
Bilstein front,Icon rear shocks
Powerstop slotted rotors
18" Wrangler AT/S LT's
2009 Fleetwood Prowler 2702BS
Primus Brake Controller
Reese DC w/ 1,000lb/10,000lb WD
rsh_757
Auburn, WA
Posted: 11/28/07 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Umm.... yeah.......OK..... I have a great idea, make sure and post this over at one of the Toyota forums. I'm sure after you pass their screening process they'll be listening. MMMMM K? Yeah.....
2008 Cougar 310SRX 5th Wheel
2005 Dodge Ram 2500 QC 4x4 CTD
2008 Nissan Armada LE
rsh_757
Auburn, WA
Posted: 11/28/07 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
I should add, I am also in the "development" business with vehicles far more sensitive, expensive and with a much higher regard for safety in which we have NEVER come close to spending a BILLION dollars on.
waroads
WA
Posted: 11/28/07 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
You're right, they appear to be much more than a BILLION and some have yet to fly.
"Since its inception in 2004, the 787 has had research and development costs ranging from $10-12 billion+ USD."
http://en.wikipedia.org/wiki/Boeing_787
*yes, i am making assumptions of where you work based off of where you live
Ron3rd
Upland, CA USA
Posted: 11/28/07 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
That's hilarious!
Notice how these tales always start with "...Met a guy..."
Funny, these "guys" can never be found or the stories corroborated.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
Page of 10
