RV.Net Open Roads Forum: Class A Motorhomes: 7.5 kw onan generator
 > 7.5 kw onan generator
retiredE8
Sioux Falls, SD (formerly - Norfolk, Va)
Posted: 10/18/07 09:49am Link  |  Print  |  Notify Moderator
Last night while sitting around watching TV the generator kicked on by itself and the TV went off. We have a 2005 Coachmen Sports Coach. We were plugged into a 50 AMP service and had no disruption of service. We do not have the auto start generator... Has anyone experienced this?
John & Paula P. (USN..retired)
2005 38' Coachmen Cross Country SE (SportsCoach 376DS)
300 Cummins/5 spd Allison
05 Saturn VUE...4 dwn
chastho
arkansas
Posted: 10/18/07 10:49am Link  |  Print  |  Notify Moderator
Yes, I came home from the coffee shop one morning and the generator was running. Are there any cats running around where you are?
retiredE8
Posted: 10/18/07 11:06am Link  |  Print  |  Notify Moderator
Did not see any cats or squirrels around. We were at the KOA in Fort Smith, AR....What do you think this might have to do with the situation.
jenks60
MS. coast
Posted: 10/18/07 11:50am Link  |  Print  |  Notify Moderator
You DO NOT have auto start? Weird.
jenks, fulltiming with the DW.
92 Southwind P3(32) 33 ft.
99 Saturn SL2
Rallys attended-TX 2, LA 2, MS 1, AL 2
MA. 1 drop in for visit.
Skip and Norine
Fulltiming since Oct 2006
Posted: 10/18/07 12:20pm Link  |  Print  |  Notify Moderator
I think CHASTHO might have mentioned the cats thinking that one of them may have made his/her way up into the generator area and inadvertently triggered the start button located on the generator itself. Then again, this is just a guess as CHASTHO didn't mention why he asked about cats.
Also, the fact that you didn't see any cats or squirrels around probably doesn't have any bearing on whether or not they could have caused it. If a cat (or squirrel) did accidentally trigger the generator, the sound it it cranking up would probably have scared the bejesus out the the little critter and they would have run away from the coach faster than an RV salesman running to a customer with a checkbook in his/her hand.
Traveling our country and seeing the sights, enjoying fun-filled days and campfire nights
See our travel pics
The rig: 2006 SportsCoach Cross Country SE
The toad: 2006 Saturn Vue
The Captain: Skip
The Co-Captain: Norine
Furry passengers: Penny & Biscuit
dave Stringham
I was hoping you'd know, California
Posted: 10/18/07 12:22pm Link  |  Print  |  Notify Moderator
It would seem strange that a cat would stand on the start button long enough that once the starter engaged and gen bumped, it wouldnt have been scared off
Skip and Norine
Posted: 10/18/07 12:29pm Link  |  Print  |  Notify Moderator
I agree.
It also seems strange that the generator would start by itself.
However, as I stated in my post, I was just venturing a guess as to CHASTHO's reason for asking.
StanleyandIris
Louisiana
Posted: 10/18/07 12:42pm Link  |  Print  |  Notify Moderator
I think it is a ghost.
Charlie in TX
Cypress
Our first trip out was to a local lake (in the off season). There were a bunch of raccoons roaming the grounds. One started my neighbors generator.
Huey Pilot
Colo Springs CO
Your problem may be corrosion or moisture in the remote start plug to the generator and this is a common problem. Look at your generator and you will see a cable coming out of the left side of the generator and there is a connector on the end, and then it runs inside the motorhome. Pull the connector apart and spray it good with electric contact cleaner and then shove it back together and back apart again to clean the contacts. Let both sides of the connector dry and then coat the pins with di-electric silicone and put the connector back together. That should fix you problem.
You can buy the contact cleaner and di-electric silicone at any automotive store.
Mike
* This post was edited 10/18/07 12:53pm by Huey Pilot *
Mike & Sandie
2005 Dutch Star Diesel Pusher Model 3810 Spartan/Cummins 370 ISL
98 CRV
U.S. Army (Retired-CW4) w/Two Viet Nam Tours
Also Flew U-21, RU-21, C-12, RC-12 as SIP
FMCA/NKK Member & Life NRA Member
