RV.Net Open Roads Forum: What did you do to your Class C MH today???
 > What did you do to your Class C MH today???
Page of 51
fisher60
Plant City, Florida
Posted: 04/27/08 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Yesterday pulled the rear window out to replace some rotted framing and wall panel. Can't believe the mfg used adhesive backed foam to seal the windows. Going back with Butyl Putty Tape. Little by little I'll pull them all and reseal. Got to be road ready by May 25th.
'01 Dutchman Express 28A, Master Tow, '07 Tuscon, '05 Honda VTX 1300
Rokk
Lake Powell, Utah
Posted: 04/27/08 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
reworked the storage compartments. stocked new sewer hoses and hookups. shined up the wheels and rims. installed a different stereo system. this coming week will be a manner of packing for a 4 month excursion starting next weekend.
zkathyz
Newhall, CA
Posted: 04/27/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Well all I did was acompany DH to Camping World to pick up a hot water temperature regulator (water was waaaay to hot)and admired the scaffolding he put over the cab so he could wax the cabover and looked at the side he buffed out (we put some scratches on it in Death Valley last week)Boy, DH needs to go camping!
The Beast and The beloved
Jayco Senecca 34SS & '84 Mobile Traveler
Always in our memories
Berticus
Boise, ID
Posted: 04/29/08 06:11am Link  |  Quote  |  Print  |  Notify Moderator
I finished off the rebuilding of the stair area. Completey removed all of the stairs and inside step, Sandblasted, powder-coated them. Welded up a new support and bolted this to the step and frame(for a bolt-on application). Repaired the inside of the underside wall and the little piece of body to the right of the outside stairs. Now to think a bit more on that Aux tank issue I am having(maybe the pickup tube is resting on the bottom of the tank and not able to get fuel through it). I will try that next or find something else to work on.
Happy and Safe Camping, Robert.
The Setup:
96' Serro Scotty 25' 4x4, Diesel, Class-C(pic coming), 86 20' Chris Craft LTD,69 Wife,02 1st Son,04 2nd Son,2 dogs (Yellow Lab & Border Collie).
kodiakdon
North Bay Ontario
Posted: 04/29/08 06:39am Link  |  Quote  |  Print  |  Notify Moderator
I modified battery compartment to accommodate two 6 volt batteries and installed an inverter.The inverter works OK but creates lines on TV.Inverter has a cooling fan, this may be causing problem.I'm also having trouble with the battery switch,power is on and I can'shut power off .I made the box out3/4 ply and angle iron, mounted solenoid onto plywood.I don't know if solenoid has to be grounded to frame in order to work.
MikeMike
St.Petersburg,Florida
Posted: 04/30/08 03:23am Link  |  Quote  |  Print  |  Notify Moderator
Started condensing my plastic containers of clothes,eliminated 1/2 of one filled with paperwork-must read all magazines and give or throw away.
jaberg
Malden, MA
Posted: 04/30/08 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Installed a new cab stereo system, then dropped it off for some major improvements including a new generator and a modern inverter/smart-charger system.
Have Rover. Will travel.
Ford C8000 based custom Super C
Follow along on the journey:
http://roverhauler.wordpress.com
trnfla
Tampa
Posted: 04/30/08 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Yesterday I installed my front hitch. Front Hitch Installation Photos
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
2hams2alaska
Illinois
Posted: 04/30/08 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Spent the day partitioning the cabinet over the dinette into individual compartments. The original configuration had three doors that all opened into a common long horizontal unit. Lots of room but everything ends up in the front third by the time we get to our destination. Put in permanent vertical dividers to make three bins and then horizontal dividers in two of the three. Much more usable room and hopefully everything stays in its own place! May do the cabinet on the other side next week if there is time.
Also ordered 6 new Michelin XPS Ribs (225x75R16E) to be installed next week. OUCH! But with 10,000 miles on the horizon this summer, we wanted the very best.
Next week it will go to the local Ford garage for the recall to fix the recall fix of last summer to the break light switch.
Five weeks and we are off to Alaka.
Mike
captainkemp
Medway, Ohio
Posted: 04/30/08 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Everyone, I installed a new 19" LCD TV on a wall mount. I'll try to get some pictures on later. Have a few more things to do to finish up. It worked good on the Wineguard Antenna, got several channels that I have never received before. Very pleased with the installation.
Page of 51
