RV.Net Open Roads Forum: What did you do to your Class C MH today???
 > What did you do to your Class C MH today???
Page of 313
Eastwacamper
Greenacres, WA, USA
Posted: 05/10/12 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Wish I could do something about the old square tv and the wood box that holds it. A cheap tv would be nice up there, newer kind. It's like above near the exit door. Any ideas welcome.
tenbear
Northern Vermont, USA
Posted: 05/10/12 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Here is my conversion from the old TV to a new LED flat screen TV. There have been several TV conversion posts, check the Tech Issues, Technology Corner and Do It Yourself sub forums.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
Eastwacamper
Greenacres, WA, USA
Posted: 05/10/12 11:14am Link  |  Quote  |  Print  |  Notify Moderator
What an idea. Thanks for that. What size tv?
Getting ready to clean the roof and the body of the motor home. Leaving in June.
tenbear
Posted: 05/10/12 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Its a 22 inch LED TV.
magik235
Central Wisconsin
Posted: 05/10/12 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
I check the differential oil and greased the RV then finished packing. I am leaving for Sedona, AZ tomorrow.
1985 Sport Coach http://www.rv.net/forum/index.cfm/fuseac........d/tid/26101292/srt/pa/pging/1/page/1.cfm
thebeach300
delaware
Posted: 05/10/12 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
changed the air filter in the v10 big air filter,going camping in morning.
pianotuna
Regina, SK, Canada
Posted: 05/10/12 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
I started and started and started the Boliy generator. This supposedly 3300 watt generator shaped object can't run a converter (723 watts max), a 462 watt oil filled heater, the fridge (305 watts), two laptops (200 watts?) and a router (2 watts).
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
pianotuna
Regina, SK, Canada
Posted: 05/11/12 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Had a bacon and tomato sandwich cooked via the battery bank with 100% solar power. The only mistake I've made was not having MORE solar.
tenbear
Posted: 05/11/12 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Checked the tire pressure and the battery fluid, also checked the toad's battery fluid. Still have to de-winterize it.
dichrodave
Independence, OR
Posted: 05/11/12 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Went to Camping World of Wilsonville, OR and had the Falcon all-terrain tow bar and base plate installed on my 2008 smart car. Pulls great!
Page of 313
