RV.Net Open Roads Forum: Tech Issues: Are you a Licensed Ham
 > Are you a Licensed Ham
Page of 14
LAdams
Northern Illinois
Posted: 10/21/07 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
WA9QYK, Advanced Class, licensed since 1965
73's
Les
* This post was edited 10/26/07 06:48pm by LAdams *
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
BillyP
Cedar Point, NC
Posted: 10/21/07 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Too many forums already. By the time I check the Jeep forum, RV forum, military RV forum... I used to spend most of my time here on the RV forum, now I try and check in every week or so. Sure don't need another RV forum... not unless I want to take RV Net off my favorites.
N1ABO
Connecticut
Posted: 10/21/07 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
I'm in also. Will be spending this winter in the RGV.
Jan, Feb and returning to Connecticut in late March.
N1ABO
Ron Butler
Federal Way WA.
Posted: 10/21/07 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
I've got my first level license, but still stumbling around with my hand held Yaesu VX 5R. It is a 3 band radio, but still not sure about using more than just on & off!! I have found that my 110 charger doesn't have the right sized connecter to plug into radio to charge the battery and it is the charger that came with the radio!! I have to contact the HAM store south of Portland to see what they have that would fit.
Still trying to figure out how to attach the portable antenna to the fiberglass roof! I have thought of epoxying a piece of metal on the roof just above the drivers seat to mount the magnetic base to.
Would be interested in a HAM forum. I'll put this in My Forums and follow what happens.
KE7BZC
Guess I should add that to my signature!
Ron & Carolyn
Sadie the Irish Terrier
Happy the Lakeland Terrier
From sailing yacht to land yacht
KE7BZC
M/V Lothlorien
GO HUSKIES
Shellback62
Sedro-Woolley, Washington
Posted: 10/21/07 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
KE7LIG this time around. Allowed the first expire.
olfarmer
Iowa
Posted: 10/21/07 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
WD0AKH here. I have been inactive for several years. My father was a ham (W0CPC) my wife and brother are also licensed but are inactive. I would check in on you guys from time to time if you had a forum on here.
73's
Ed
ZenfookPower
Posted: 10/21/07 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
73's
* This post was edited 10/28/07 05:09pm by ZenfookPower *
Wherever I happen to park
Posted: 10/21/07 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
KE7BZC has a point. Some of us studied electronics (Of course I got my license while in high school) and read the owners manuals over and a over and a over again so we know a bit about our radios. Others can use an Elmer or three, perhaps a ham forum might not be a bad idea her, only call it "Elmer's Place" or some such.
KE7BZC: Re Epoxying a sheet of steel to the roof, not a bad plan really, but do not trust epoxy, secure it with good strong bolts in the corners. However a few other things to think about,, A 2 MTR antenna is, at the minmum 19" tall, (Full size) of course you can use a "Rubber duck" (Rubber covered spring) or even a "Stubby" Very short) but on some RV's you are getting close to 13'6" and antenna damage is very possible. I put a diamond dual band on the mirror arm on my rig, it's a "No ground plane" type and works quite well
The antenna comes with several mount type options. One is PL-259, though not the best connector for VHF/UHF (Even if it's nick-name is UHF connector, from back when UHF was 2 digit MHZ, I'm not QUITE that old) but you can get 2" PL-259 barrel/feed through connectors Might be long enough to do some good (I truly do not know the thickness of my roof)
The Ham Store may have some antenna suggestions for you.
GWMAYES
Albuquerque, NM
Posted: 10/21/07 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
KD5QE here.
The call sign plus 146.52 is stenciled on my spare tire carrier on the back of the fifth wheel. Also, along with CB Ch13.
I get far more calls on 146.52 than I do on that supposed RV channel 13.
George in Albuquerque
2003 Silverado 2500HD ExtCab, ShortBed 4X4, Duramax/Allison, Jordan 2020 Brake Controller, Transfer Flow 45 Gal, Reese 16k Slider (converted to non-slider), Honda EU3000
2001 Sunnybrook 27RKFS
smkettner
Posted: 10/21/07 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
I was wd6eup (novice class) when I was about 13. I lost interest and let it expire.
Page of 14
