RV.Net Open Roads Forum: Toy Haulers: New owner - any tips?
Search only in Toy Haulers
 > New owner - any tips?
copter
Viagra helps a
Posted: 10/23/07 07:21pm Link  |  Print  |  Notify Moderator
Un-hook the shore power and let it sit for a while before hooking to your TV and take a look at the voltage(take a volt meter) on the batts. If it drops lower than 12v you might have some issues. Be sure and check the battery water level too.
06 GRAYSTONE LBZ | MBRP 4" TURBO BACK | NOR*CALTRUCK 4-6 LIFT | AMP STEPS | 4300k HID'S | KMC DIESELS
06 COACHMEN ADRENALINE 314FS TOY HAULER | CLEAR LEDS | A&E POWER AWNING | ON BOARD AIR
05 HONDA 450R & HONDA 400EX
__________________________________
WhitehouseLV
Formerly Las Vegas, Now Big Sky State - Montana
Posted: 10/23/07 07:42pm Link  |  Print  |  Notify Moderator
Mandalay Parr wrote:
Check out the generator. Run it under load. 35 hours tells me it sat too long without being run....not good! I have over 600 hours on my '05.
Take an experienced RV'er with you. They will know how to check it out.
fewer hours on the generator is a good thing. My parents purchased a 2006 Weekend Warrior (equivalent to an 05 Raptor) with only 2 hrs on the generator. No problems to speak of. Onan recommends changing the oil & filter at the first 20hrs so you might plan on changing that. Like everyone here said, use a checklist. Just make sure everything works. Ask the owner to go over how things work and with their permission video tape it. Nice reference for your first few trips and it will probably keep them honest. Not sure if Keystone will give the info out or not but I would try to see what warranty work has been done and how frequent. Good luck and let us know how it went.
Traveling Whitehouse
2006 Keystone Raptor 3612DS
2004 Chevrolet Silverado 3500 CC LB DRW Duramax LLY 4x4
Reese 20K Hitch
Prodigy Brake Control
2007 Honda Rincon & 2000 Honda Rancher
Broccoli1
Los Angeles
Posted: 10/23/07 08:39pm Link  |  Print  |  Notify Moderator
Rageous wrote:
Thanks for all your input.
This is an assume web site with assume people.
06 F250 V10 SB 4x4 Gulp Gulp
WW FSC2800
Rincon 650, Rhino
Power Wheels 750
"Shoot, I'm the world's best backwards driver!"
copter
Viagra helps a
Posted: 10/23/07 08:52pm Link  |  Print  |  Notify Moderator
That's what I thought... Doesn't that statement make an A$$ out of you and me?
bugman696
Yuma, AZ
Posted: 10/23/07 10:06pm Link  |  Print  |  Notify Moderator
I have the exact same trailer...I have had multiple problems with the converter (located under the fridge) I have had to have them replace the propane tank regulators and the water pump makes an EXTREME amount of noise...I dont want to want to steer you away from this trailer at all it is great, just wanted you to know the problems I have had in the last 3 years...good luck...and make sure you turn on the water pump....make them fill the tank with a little water and unhook the presure line and listen for a big noise...
Rageous
Colorado Springs, CO
Posted: 10/24/07 06:56am Link  |  Print  |  Notify Moderator
bugman696
I checked out the water pump, it seemed to have good pressure. It made a "pump" noise, that they make some sound and I was told that is normal.
What type of converter problems did you have? What should I look for?
Thanks for your input.
* This post was edited 10/24/07 08:28am by Rageous *
Rageous
2003 F-250 BioSmoker
2005 Raptor 3018 TT
2003 KLX 400
2004 Bombardier Traxter Max
tdharley
Manorville, NY
Posted: 11/01/07 05:45pm Link  |  Print  |  Notify Moderator
One of the first things I did was replace the water pump with a High capacity Shur-flo. I also did that with my Heartland fifth wheel. Much quieter.
Check for noise dampeners under the pump. I use 3 tennis balls for dampeners, works great!!!
Broccoli1
Los Angeles
Posted: 11/01/07 05:54pm Link  |  Print  |  Notify Moderator
Rageous wrote:
bugman696
Normal sound- some are worse than others but still normal for it to make some noise
Strabo
Desert Dweller
Posted: 11/01/07 06:31pm Link  |  Print  |  Notify Moderator
Tip: If the water pump is making noise that means its running.
2005 Ford F150 SC FX4-Procomp 6" lift-Fabtec Lightbar-Magnaflow 3" CB-K&N C.A.I-Firestone Airbags-Prodigy-Overhead DVD
2003 24' Jayco Talon ZX TH
2007 Rhino 660 SS106-ITP-K&N-JetKit-T4-CDI-CVT-Grant-Holder LED LightBar
1992 CR 250
1995 KX 250
MoombaHauler
Reno, NV
Posted: 11/02/07 01:32pm Link  |  Print  |  Notify Moderator
Copter - You do realize that if you keep posting like this, pretty soon you will have a 'Senior Member'. Then it's Viagra and weak stream for you. Better pace yourself.
Dave
2000 Ford Expedition Eddie Bauer 4X4
2005 Ford Expedition Limited 4X4
For the Desert:
2008 Thor Tahoe Lighthauler 26FS
1998 XR400R
2004 TRX250EX
2001 KLX300R
2001 XR100R
For the Lake:
2005 Moomba Outback
Skis, Wakeboards, Kneeboards
