RV.Net Open Roads Forum: Travel Trailers: Inverter making noise
 > Inverter making noise
killbilly
Wisconsin
Posted: 10/23/07 06:19am Link  |  Quote  |  Print  |  Notify Moderator
I've noticed the last time out camping that when we have certain lights on I get a humming noise coming through the sound system when watching tv. I could always hear the fan come on with the inverter and there always seemed to be a little noise in the sound system but now it seems to be getting worse. Any ideas. Loose wire, or is the inverter going bad? Turning on certain lights can make it noisier.
foneguy493
northeast ohio
Posted: 10/23/07 06:24am Link  |  Quote  |  Print  |  Notify Moderator
i have the same typ of problem but only when we turn off all 12v appliances....but if i turn on 1 light...the noise goes away
take pictures.....leave bubbles.....lets go diving
places weve been
04 1500 ram 4x4
08 hornet 27b hideout
trails2004
Wyoming
Posted: 10/23/07 06:27am Link  |  Quote  |  Print  |  Notify Moderator
Possibly the type of inverter is it a mod sine or pure sine? I have been told if you do not have either of these two types you may experience interference with you electronics
2002 Dodge Ram 2500 SLT 4x4-AFE Cold Air,4"Exhaust,Superchip,Toyos,Ranchos,Dual Air III- Firestones
2004 Hallmark Cuchara XL 9.5 WFCO 9845,Xantrex XBM,Honda 2000,1997 Grumman GV19TC- Crew Wifey,(Odin,Bridger & Sam,Wirehairs)
killbilly
Wisconsin
Posted: 10/23/07 08:19am Link  |  Quote  |  Print  |  Notify Moderator
The TT is a 2006 Rockwood 8296SS. Not sure what kind of inverter it has. Is there a fix for this, its really kind of annoying.
Rick From Sequim
Sequim, WA
Posted: 10/23/07 08:26am Link  |  Quote  |  Print  |  Notify Moderator
killbilly, do you really mean INVERTER (makes 110 volts when connected to a 12 v battery) or are you talking about the trailer's CONVERTER (manke 12 volts when pluged into shore power)?
Rick
& wife Loie & Kodi Dog (blk male std poodle)
1995 F-250 460 Banks (wow!) & 2005 25' Bigfoot RQ
killbilly
Wisconsin
Posted: 10/23/07 10:50am Link  |  Quote  |  Print  |  Notify Moderator
I'm sorry , yes I meant to say converter.
n3qdz
Whitehall Md
Posted: 10/23/07 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Yea ours does the same thing. I think but not sure but I think the battery might be shorted or maybe going bad in some way I think. I have not yet had a chance to change the battery to test my theory.
I think the converter does not like a bad battery. I does not look all sophisticated i think you you disconnect the battery the noise might go away.
Matt Christopher
06' Forest River Cherokee 31Z+
03' Ford Excursion Eddie Bauer 6.0L PSD
14,000lb equalizer hitch
Brake Smart controller
Attwood 3,500 electric jack
JT Strong arm stabilizer jacks
"Sidney" Chessie
"Hunter" beagle
"Sasha" cocker spaniel
pete42
Jamestown, Ohio
Posted: 10/23/07 11:19am Link  |  Quote  |  Print  |  Notify Moderator
There are a lot of things that could send "electrical noise" into you system.
a loose solder joint, a capacitor going bad, or even transformer putting out a signal that your system hears.
Have you ever used computer speakers powered by batteries and run them using a wall plug batteries no noise, plug lots of hum.
Could be easy fix for a technician then again could be bad ground wire on converter
2oldman
WA
Posted: 10/23/07 11:22am Link  |  Quote  |  Print  |  Notify Moderator
You may want to change the topic heading (and your first post) to avoid confusion.
wrenchbender
Phx
Posted: 10/23/07 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Many converters have a squeal under load.Its the transformer core.If the converter has a cooling fan, check it for dirt and obstructions.
