RV.Net Open Roads Forum: General RVing Issues: Water Heater Draining Q??
 > Water Heater Draining Q??
DznyFan
Lorton, VA
Posted: 10/27/07 10:41pm Link  |  Print  |  Notify Moderator
Get yourself a bulb type siphon from Wally World, just a few bucks. Remove the plastic plug from the water heater. Insert the small section of the hose into the hole and let the curved hose angle down into the water heater. Put your thumb over the other end of the hose. Squeeze the bulb a few times. If there is any water, release your thumb from the end of the hose and let it flow.
On my TT if I open the low point drains (I have three) and remove the plug from the water heater not all water drains out. The openings in the water heater for the lines and the plug do not sit on the bottom of the tank but a few inches above trapping the water as it falls below the openings. When I use the siphon it seems like maybe a half gallon or so of water still comes out.
2006 Fleetwood Wilderness 3102BDS
2004 Excursion XLT 4x4 V10 4.30
Ride-Rite Air Bags | Air Lift SureSet
Hensley Arrow | Prodigy
Honda EU2000i Gennies
Garmin nĂ¼vi 350 | ScanGaugeII
_________________________________________
Me, the Wife & the Kid
Mousefart
New Jersey
Posted: 10/28/07 08:09am Link  |  Print  |  Notify Moderator
I drain my water heater between trips through the low point drains all the time, so yes, this is probably where the water went.
I only pull the drain plug on my water heater once or twice a year when I sanitize the system, that's it.
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab 4x4, 4.7L HO, factory tow, 3.92 gears.
Equil-i-zer Hitch, Prodigy.
Yamaha EF2400 Generator (quiet, cause I care!)
Wherever I happen to park
Posted: 10/28/07 01:39pm Link  |  Print  |  Notify Moderator
Camping World sells a water heater saver thing.. It's a wand you hook up a garden hose, stick it in the bung and it flushes out the tank (Kind of like the black tank flusher but everything comes out the same hole it goes in)
Try one
Also pop the lever on the TPR valve to let air enter at the top of the tank
