PSDExcursion
Millstone NJ
dfb wrote: Toyota's RELIABILITY has fallen behind FORD!!!! OMG,, what's this world comming to???Next thing you know they won't be the number 1 seller anylonger.... Oh wait, GM is number 1 again!!!!
CR still has Toyota ranked third overall in reliability, behind No. 1 Honda and Subaru.
2002 Chevy Express 3500 8.1 155" WB passenger van
41 Ft 2003 Thor Citation 41-ZBSR TT w/ Hensley Arrow
Flashman
Tucson, Aizona, USA
This is just a show truck.
You can get 500 hp out of a 4 cylinder if you push enough air in it.
It means nothing.
Are they really going to market it?
I don't think so. The Regular Tundra is having a hard enough time staying on the road.
Problems with:
Engine - cam shafts
Frame - flex
Tail gate - breaking
Transmission - shifting
The only thing that works is the rear view mirror.
Ron3rd
Upland, CA USA
Flashman wrote: This is just a show truck.
It means nothing.
Problems with:
Engine - cam shafts
Frame - flex
"Problems with:
Engine - cam shafts
Frame - flex
Transmission - shifting"
Wrongo,
Camshafts: Isolated to about 20 early production vehicles, most never released to the public. Now a non-issue but still circulates the web and provides old fodder for Tundra Bashers.
Frame flex: Never shown to be a problem, or even undesirable in the real world. Fodder for unsophisticated Tundra Bashers with no engineering background or knowledge that were hoodwinked by the Ford-leaked youtube video designed to show Tundra and Chevy in a bad light.
Transmission: Never a problem with the superb 6-speed trans. "Rumble Strip" problem traced to some bad torque converters and problem solved on all new build models. If you have an early production model, problem shows up very soon. Worst case scenario: you get a new upgraded torque converter.
Tailgate: Possibly a problem depending on whether you use the tailgate to load heavy objects. If you do, avoid this truck.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
foneguy493
northeast ohio
yea 10.s klbs towng 4:30 gears ...my truck would do that too with 4:30's but i do like the rear power window..not the doors but the rear window i would love to have that
take pictures.....leave bubbles.....lets go diving
places weve been
04 1500 ram 4x4
08 hornet 27b hideout
JIMNLIN
Big Cabin, OK
sounds like just another high horsepower small block in a small pickup. Other simular small 1500 high hp trucks and from a towing standpoint they .................. just like the others.
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
webwrangler
Tetonia, ID, USA
ib516 wrote: Wonder where all the naysayers are now saying "what we don't need is another high powered pickup".....
OK, I'll bite: WHAT WE DON'T NEED IS ANOTHER HIGH POWERED PICKUP! What we need is a pickup with reasonable power that gets really good fuel economy. The 07 Tundra is almost there--it just needs a little more fuel economy.
JMHO but what do I know?
2005 Rockwood 2104
2000 Toyota Tundra 4WD
Equalizer
Prodigy
rsh_757
Auburn, WA
Toyota isn't stupid enough to waste money to mass produce that thing. They really aren't a high-risk type corporation. They produce stuff that they know people will buy, that rig is more like the SRT10 Ram which is a real niche market. I would be shocked to see this being in Toyota's future. Cool truck anyways. Maybe if they do build them like crazy Ford would consider using the 500hp Shelby Cobra engine in the F-150. I wonder if you can get it from the factory with a narrowed rear so you could run super wide wrinkle walls for traction
2008 Cougar 310SRX 5th Wheel
2005 Dodge Ram 2500 QC 4x4 CTD
2008 Nissan Armada LE
Flashman
Tucson, Aizona, USA
Ron3rd wrote: Flashman wrote: This is just a show truck.
It means nothing.
Problems with:
Engine - cam shafts
Frame - flex
"Problems with:
Engine - cam shafts
Frame - flex
Wrongo,
Superb 6-speed
Read this:
http://www.pickuptruck.com/html/news/toyota/tundra/transmissions/page1.html
rsh_757
Auburn, WA
Flashman wrote: Ron3rd wrote: Flashman wrote: This is just a show truck.
It means nothing.
Problems with:
Engine - cam shafts
Frame - flex
"Problems with:
Engine - cam shafts
Frame - flex
Wrongo,
Superb 6-speed
Read this:
Flash, no use of mundane facts or articles that shows the Tundy in a negative light will phase Mr. Toyota. Anything else is a thought out conspiracy by known Toyota bashers!!!!
Keith99RS
Suffield, CT
rsh757 - Even you must admit Flash is blowing each of his nitpicks out of proportion. Ron3rd is stating fact with what he posted. Toyota is running a "gasp!" c channel frame under the bed area of the Tundra. According to them is is supposed to have controlled flex and allow for a better ride. All your HD trucks run C channels as well and guess what? Their beds shake also. Camshafts were a non issue less than a month after it came out there was a problem. Super small number and instantly addressed. Trannies were the same way. Tailgate strength is the one issue that has legs apparently. I have seen pics and it does look chintzy.
FWIW give me 5 more mpg with any of the current HP numbers on all current small blocks from all manufacturers and I would be way happier than having more HP. HP is nice but it is getting more and more that mileage would be better as a sales tool. How many buyers wallets can afford the truck only to sell or pass on it after they can't afford to feed it? One huge reason truck sales have slowed across the board. The exceptions being fresh redesigns. Year 2 will be the true test. After all the "latest and greatest trade my perfectly good truck in to be the first to have the new one" people already have their new truck.
Smoke 05 Titan SE CC 4X4
K&N panel filter
PRG 2.5" Leveling kit
Bilstein front,Icon rear shocks
Powerstop slotted rotors
18" Wrangler AT/S LT's
2009 Fleetwood Prowler 2702BS
Primus Brake Controller
Reese DC w/ 1,000lb/10,000lb WD
