Dirtclods
Newport Beach
So....here goes I seen a few of those cables and sometimes chains to keep the large toy hauler door level when opened for like a patio area and also seen jacks underneath.I not sure what kind of hardware to use either or how is mounted. Pictures??
Your thoughts?
Moderator's Edit: Moved to Modifications & Accessories.
edited 10/30/07 10:08am by an administrator/moderator *
dhamblet
Olympia, WA
Get some galvanzed flanges and 2" pipe about the same length as the distance from the hinges to the ground to screw into them. Screw the flanges to the top of the door. When you want a patio screw the pipes into the flanges and level it with blocks. You might also want to carry a couple of shorter pipes inn case the ground slopes up.
2005 Dutchmen 35SRV, Pergo floor, 5th Airborne, JT Strong Arm, Kodiak Disk Brakes, Backup camera
2006 Dodge CTD RAM QC 3500 LWB 4WD, Reese 16k, Airlift, Pacbrake, Britebox, 60g aux fuel tank
04 HD Ultra, CanAM 400MAX Quad
Spending my kids inheritance
Al/Reeni
Ft Myers, Fl
Dirtclods wrote: So....here goes I seen a few of those cables and sometimes chains to keep the large toy hauler door level when opened for like a patio area and also seen jacks underneath.I not sure what kind of hardware to use either or how is mounted. Pictures??
Your thoughts?
I did this.
Sometimes it's hard to use the jacks.
Al/Reeni
Ft Myers, Fl
Just wondaering why you have the same question posted twice?
Seems the quality of the answers might be better if you just kept it to one thread. Kinda confusing.
Y-Guy
Tri-Cities, WA
Dirtclods - What toy hauler do you have?
Forced Family Fun... They'll thank you later for it!
Have you checked out the new RV.net Blogs?
Dirtclods
Newport Beach
Y-Guy wrote: Dirtclods - What toy hauler do you have?
07 19" Attitude
mjrfd99
Jersey Shore
I'm in the process of getting a enclosure to turn our ramp into a room. Since we have alot of tiedowns for the M/C's I'm gonna weld a couple U bolts inside the frame of the door and some onthe gate. I figure 2 1200 lb tiedowms on each side will be plenty and cheap.
Bonofied Suiter
Las Vegas, NV USA
I use the cables. They won't settle into the ground or ever need to be leveled once they are installed. I can have my patio up in about 2-minutes or less. Different trailers have different ramps but installing mine was a snap and we have used it many times with no ill effects on the trailer.
juzplanekrazy
Huntington Beach Ca.
The cable option is a better way to go I think, ya never know what type of ground conditions you'll be park in. The cables will always work.
gouldc
Edmonton, Alberta Canada
Wanted to revive this thread to get an update from those who have installed the cables. Have you noticed any issues, i.e. twisting of the door, pulling of the bolts through the mounting holes?
Thinking of going this route. Just don't want to cause long term damage.
03' Lariat F350, 6.0L Short Box *SOLD*
04' Jayco Eagle 28FKS *SOLD*
08' FX4 F350 6.4L Dually Long Box, Black on Black PICTURES
07' Keystone Raptor 3712TS PICTURES
Reese 18k Signature Series Hitch
