RV.Net Open Roads Forum: Technology Corner: Solar Panel
 > Solar Panel
scouser
Mnt Forest ON Canada
Posted: 10/30/07 12:25am Link  |  Print  |  Notify Moderator
Hi,
I'm thinking of hooking up a solar panel (5watt)to my unit this winter instead of taking the batteries out over the winter, has anybody tried this before? any issuse I should know about? Your thoughts!!!
Thanks Mal
* This post was edited 10/30/07 12:50am by scouser *
CHEERS..... MAL & IRENE
1993 chev 2500 6.5td auto,
3:73, 2wd, ext cab,LB
2005 Outback 28 FRL-S
mcgillagorilla
north pole ak
Posted: 10/30/07 12:57am Link  |  Print  |  Notify Moderator
one thing i learned from my solar panel on roof you have to brush the snow off or they do not work very well.
bob mcgill
lv2rom
Kansas City, Missouri
Posted: 10/30/07 05:45am Link  |  Print  |  Notify Moderator
Why don't you post in the Tech Issues forum...you'll get lots of imput over there...Brian
2005 F350 Dually -AFE air box/MRSP exhaust/Bags/Bilsteins/Energy Susp./Michleins
2002 Hitchhiker Fiver 29.5 RLBG - Moryde Pin/Gas shocks/Michelin XPS Ribs
1996 Layton Fiver 21ft. Totally reconditioned..Love it!!
hwybnb
Posted: 10/30/07 05:54am Link  |  Print  |  Notify Moderator
It will work if you keep the snow off but 5 watts ts probably not enough. I use 15 watts, and we get more sun than you will.
tom_kat
way upstate new york/lake george area
Posted: 10/30/07 09:43am Link  |  Print  |  Notify Moderator
15 or more watts would be better 5 watts dont do much for keeping the batterys up in winter.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
2oldman
WA
Posted: 10/30/07 09:53am Link  |  Print  |  Notify Moderator
Solar trickle charge post
sirdrakejr
Las Vegas, Nevada
Posted: 10/30/07 11:48am Link  |  Print  |  Notify Moderator
Moved from RVing in Canada & Alaska to Technology Corner.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
SideHillSoup
South Eastern British Columbia
Posted: 10/30/07 12:28pm Link  |  Print  |  Notify Moderator
I use a Canadian Tire 1.8 watt solar panel and have for years. I have one in the windshield of my boat all winter and batteries stay charged just fine. I also have one for my 5th wheel and it also is fine. The trick with the 5th wheel is how to get it inside the 5th wheel and close enough to my power source to plug into. Keep the snow away from the panel and you should be OK, plus southern exposure is a must
2006, Komfort 261FS
2007 Sierra SLE, 2500 HD / 4x4 / Duramax with a 6 speed Allison Transmission
Chuck&Gail
In the Colorado Mountains
Posted: 10/30/07 05:40pm Link  |  Print  |  Notify Moderator
As long as parasitic drains like propane and smoke detector are removed (I pull one fuse) you should be fine. I've done it for over 20 years on cars and RVs. Note it will MAINTAIN battery if 5 watts, not charge it.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Wherever I happen to park
Posted: 10/30/07 06:53pm Link  |  Print  |  Notify Moderator
I have a five watt in my car... Alas, 0.5 watt is closer to how much I get out of it.
 > Solar Panel
