fleetwood05
In the East for now
I will be winterizing my travel trailer this weekend and was goig through the checklist for winterizeing that I got from RVeducation 101 and had a question to one of the items.
"Drain and flush the gray and black water holding tanks. If the RV doesn’t have a built in flushing system clean the black tank out with a wand. Lubricate the termination valves."
I am not sure what they mean by the termination valves. are they the handles that release the black and grey tanks? This will be my first attempt at winterizing. Last year I paid to have it done.
Thanks for the help.
M GO BLUE
Southgate, MI
Empty all your tanks...drain the water heater and then set your bypass valves (if so installed)...drain the low point drains...if so equipped with a bypass system pump anti-freeze via hose in a bottle of AF throughout the system, starting with farthest faucet from pump and make sure to fill ALL water lines...trun off pump and open a faucet, go outside to city water connection and push in on the white button (check valve) until AF comes out...drains tanks one last time and then close...pour AF down each drain and into toilet...and you're finished!
I'm assuming the termination valaves are the sliding "doors" to shut off the tanks from draining...the AF in the tanks will keep the "doors" lubricated
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fith wheel
Built-In Onan 5500W generator
fleetwood05
In the East for now
I was making the same assumption.
Thanks that helps.
Chuck&Gail
In the Colorado Mountains
I empty waste tanks completely. Then spray silicone spray up the drains while operating valves. Also spray a little on shafts. Really helps. I spray toilet seal also.
Never noticed AF helped much on ours.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
arboscamper
South Dakota
Is spray silicone the same as WD40??? I know dumb question, but wondering. If they are not the same would WD40 work??
1993 Chevy K1500 4X4 5.7L V8 141.5 inch Wheelbase & 3.73 Gear Ratio
2004 Skyline Nomad North Trail Model #2480 UVW 4385, GVWR 6500.
Rumtan
Alberta
Silicone is a lubricant....WD-40 is a degreaser. Hope that clears that up for you. stick with the silicone.
2002 Palomino 22'
2002 Chev Silverado V8
Fish-O-holic
Loopy
Western Pennsylvania
M GO BLUE wrote: go outside to city water connection and push in on the white button (check valve) until AF comes out...drains tanks one last time and then close...pour AF down each drain and into toilet...and you're finished!
OK, stupid question, I don't think I have a "white button" at my city water connection.
Another stupid question, why would you drain the tanks after you've ran antifreeze into them from the faucets only to add antifreeze back to them again? Couldn't you just leave the antifreeze in there that you just pumped out of the faucet?
Bryan , Jess , and our Parsons Russell Terrier, Melvin
1999 Chevrolet Tahoe 4D 4WD 5.7L 3.73" Rear End
Reese Strait-Line Dual Cam Weight Distribution Hitch
Tekonsha P3 Brake Controller
2008 Jayco Jay Flight G2 20BH and Mods
windriderjr
Massachusetts
The "white button" is under the screen in the city water connector. You need to pry out the screen, it's held in by a rubber washer and friction. Use a blunt tool, I used the screw driver blade on my swiss army knife.
DW and I in our Gulfstream Amerilite 21MB
Chevy Silverado 2500 HD - Duramax Diesel 6.6L - Allison Tranny
"We can categorically state that we have not released man-eating badgers into the area." - Major Mike Shearer - British Army - Basra, Iraq
larryandpaula
Vancouver BC
Good question. I wondered this, too. Seems redundant to pour more pink antifreeze into the p-traps when you've already run the taps with pink coming out. I just ran the pink stuff into the drains (so they're in the p-traps) and drained the tanks. The pink stuff is still in the p-traps, isn't it? It doesn't come out until it's rinsed out - correct?
Larry, Paula and Two Kids (ages 5 & 3)
2006 Dodge Ram Power Wagon
2007 Jayco Jay Flight 20BH
