RV.Net Open Roads Forum: Travel Trailers: Jayco JayFeather Thermostat
 > Jayco JayFeather Thermostat
Hornet28BHDS
Parker, PA
Posted: 11/02/07 07:46pm Link  |  Print  |  Notify Moderator
My aunt and uncle have a JayFeather 213, as you probably have heard (). We were looking at the darn thermostat and could not firgure out how to use the thing! Could any JayFeather owners provide some wisdom? I believe it is an Atwood heater/thermostat. It is not like ours, which controls all systems, it just does the furnace.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
skipnchar
Topeka Kansas USA
Posted: 11/02/07 07:58pm Link  |  Print  |  Notify Moderator
It PROBABLY has a small switch on the bottom that must be opened to work. I had one like that on my Coachmen and it was hard to operate. The switch is small and it takes some force to move it. When it DOES move it only moves about an eighth of an inch. Good luck / skip
chevyman2
missouri
Posted: 11/02/07 11:37pm Link  |  Print  |  Notify Moderator
I think Skip is right. You likely have an on/off switch right on the bottom of the T-stat. Check that out.
Tim-DW(Kathy)-DS(KEN)
04 AVEO-DD, 03 JEEP GRAND CHEROKEE, 95 Firebird(da toy)
07 COACHMEN SOA 32FKS(stress relief center)
If Im not at the CG---I'll be somewhere else!
Total nights camped in 08 = 45
2001tundra
Surry , NH
Posted: 11/03/07 09:40am Link  |  Print  |  Notify Moderator
Hi, on my new trailer the Atwood themo Switch is on the top right and is very tight to operate. every time you shut down you think that you are going to break it. Person who designed it never used it, Norm
2001 Tundra TV , 18 ft Cikira Classic Cruiser
Chickenhawk
Philippi, West-By God-Virginia
Posted: 11/03/07 09:57am Link  |  Print  |  Notify Moderator
Norm is right, it is on the top right and it is darn hard to turn on. We have the same unit as you and I hate the thermostat! Once you turn it on you still have to constantly adjust the temp to get it comfortable in there. You really have to push on it to switch it on, it will almost feel like you break it off. Hope you are enjoying your 213 like we are!
2007 Nissan Titan CC SE 4x4 w/ Tow and Off-Road Pkg
2007 Jayco Jay Feather 213
