JSowders you must be running E rated load range tires so what if your fifth was G load range tire and Michelin doesn't make that tire?? Not much else is available in G load tires. chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
Problems with the GY G rated tire is creating a real problem for large trailer owners. GY will teach the chinese how to make a good tire, which is both good and bad! Michelin is missing the boat by not supplying a XPS RIB in a 235/85R16 G rated tire.
Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
