RV.Net Open Roads Forum: Fifth-Wheels: Replacement A/C unit
 > Replacement A/C unit
natsgnik
Clovis, CA 93612
Posted: 11/04/07 02:59pm Link  |  Print  |  Notify Moderator
I have 2004 Keystone Sprinter fifth wheel. I am considering replaceing a damaged roof A/C unit. I have a Model 57915.331 Duo Therm Brisk Air 13,500 cfm unit. I have access to a new take off unit removed from a 2007 Skyline fifth wheel. It was replaced by a low profile unit because it was too high the storage room. It is a Duo Therm Brisk Air, 13,500 cfm, model 57915.541. It is equipped with a remote control devise and mine is not, otherwise I believe the rest of the internal equipment appears to be the same as mine. Can this switch be made and will the electrical hook up be the same. Does anyone know if this is will work and are there any pitfalls I need to know about? Any help appreciated.
Thanks,
SK
donhov
near Jackson Michigan
Posted: 11/04/07 03:07pm Link  |  Print  |  Notify Moderator
Not sure about the differences but physically it should be an easy swap. Electrical is black to bblack/white to white and ground unit. Not sure about teh remote so if there seems to be any type of additional box or whatever with the newer unit make sure you get it all as I would think the remote is controlliing the unit at teh top of it.
Nothing factual, jsut what I think so be sure you check out all the options. If really still in doubt call the unit's manufacturer and be sure.
2003 Cedar Creek 30RLBS
2007 Dodge 5.9 Cummins Turbo Diesel 325hp/610Tq
4x4 3.73 axles short bed
Inferno Red W/Gold pinstripping
gillguy
Valdosta, GA
Posted: 11/04/07 07:53pm Link  |  Print  |  Notify Moderator
If you can undo the old one, then it's an easy swap.
Well other than getting the new one up on the roof. The old one goes down fast.
Bobby (USAF Retired)
2007 Chevy 2500 LBZ Duramax C/C, S/B 4X4
2006 Rockwood 8317SS
1973 Airstream Ambassador
Old Town Penobscot 16
JSowders1
Emery SD
Posted: 11/05/07 09:56pm Link  |  Print  |  Notify Moderator
They are the same unit electronically so they will replace each other even thou the new one has a remote control.
2000 1T Ford PSD SC Dually 2WD
2005 Grand Junction 35TMS
Mor-Ryde Suspension & Pinbox
Movin View
Beagle-Maggie
Lifetime GoodSam Member
hypoxia
Arizona
Posted: 11/05/07 10:22pm Link  |  Print  |  Notify Moderator
The only pitfall I can imagine is if you might want to replace it with a 15000 BTU unit.
I am a fan of the bigger units because they have more cooling capacity and in more mild weather can be run on low speed, less noise. On the other hand if your generator is lacking in capacity the smaller one could be best.
Jim
My Trailer Rebuild Project
2008 F-350 6.4 Diesel
1990 Collins 24' 5th Wheel
2001 Jayco 311RLS 5th Wheel
ATV Trailer follows the 5er
