RV.Net Open Roads Forum: Fifth-Wheels: Honda generator sizing
 > Honda generator sizing
4tr
Maine
Posted: 11/05/07 09:01pm Link  |  Print  |  Notify Moderator
Hello, I am thinking about purchasing a Honda eu1000i generator to run my Wildcat 31QBH FW. I am only looking to power the lights, furnace this winter, and maybe a TV. Do you think this will be adequate. I have no interest in powering the AC or the microwave. Nor will I be powering a coffee pot, hair dryer, electric heater, etc.
HarryWM
Wherever we are parked this time.
Posted: 11/05/07 09:08pm Link  |  Print  |  Notify Moderator
The 1000 should do it fine but we have that unit and quite often wish we had spent the additional amount and bought the 2000.
Harry
With wife Carole 10 yrs fulltiming
Retired U.S. Army
2002 Carriage LS 37' 5er; 2006 Lance 1181
2008 F-450 King Ranch 4x4 fully loaded
2004 Jeep Grand Cherokee toad
SKP # 54751
Geocacher "DosTortugas"
Harry's BLOG
4tr
Maine
Posted: 11/05/07 09:09pm Link  |  Print  |  Notify Moderator
For what reasons do you wish you went with the 2000? I found a used 1000 for $450, that is why I was considering the smaller.
Chris
Shelter Bay, Wa
Posted: 11/05/07 09:21pm Link  |  Print  |  Notify Moderator
I will sell my EU1000i for $450, I want a 2000. Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
JSowders1
Emery SD
Posted: 11/05/07 09:24pm Link  |  Print  |  Notify Moderator
if your only concerned with power for lights and the furnace and maybe tv, the 1000 will do fine. You're basicly running on 12v as if dry camping so the gen would be used mainly to power the converter to recharge the batteries. No problem there.
2000 1T Ford PSD SC Dually 2WD
2005 Grand Junction 35TMS
Mor-Ryde Suspension & Pinbox
Movin View
Beagle-Maggie
Lifetime GoodSam Member
FisHin2Dmax
Utah
Posted: 11/05/07 09:42pm Link  |  Print  |  Notify Moderator
I started with a Honda 650, then 1000ei then 3000ei and now have two 2000ei's. The 3000ei was nice, but too heavy to tote around!
You will be amazed at the versatility of the 2000! I bought a second 2000 and run it in parallel to run my 15 K BTU A/C when it's hot out. Normally I just run only one generator for TV and lights and charging the batteries. While the 1000ei will do the basics, why not spend a little more and have the option to run the microwave and other appliances. The 2000ei is just as quiet and not much more weight than the 1000ei.
If you do opt for 1000ei, you can also use it in parallel with another 1000ei unit for 2000 Watts total.
You can't go wrong with Honda electronic Inverter generator no matter what the size!
2003 GMC HD 2500 CC 4x4 DuraMax/Allison
2008 Sundance 2900MK
HarryWM
Posted: 11/05/07 11:31pm Link  |  Print  |  Notify Moderator
I use my 1000 to back up/supplement my solar system with inverter. The 1000 only produces 7.5 Amps of power at 120 Volts. It would be nice to have the option of using the AC, microwave, or coffee maker. As I said, the 1000 works but the 2000 would be better.
randy&shereen
Jackson, MI
Posted: 11/06/07 03:58am Link  |  Print  |  Notify Moderator
FisHin2Dmax wrote:
.....You will be amazed at the versatility of the 2000!----Normally I just run only one generator for TV and lights and charging the batteries. While the 1000ei will do the basics, why not spend a little more and have the option to run the microwave and other appliances. The 2000ei is just as quiet and not much more weight than the 1000ei.
I had a 1000 Yamamaha for the exact thing you want do do and it did a fine job and would run 8 hrs on .75 of a gallon of gas. This was a older unit before the inverter type so newer are better. I changed to a 2000 Honda because of the coffee pot, toaster, and microwave that the 1000 would not run but the 2000 will. Randy
2004 GMC Sierra 2500HD SLT CREW CAB LONG BOX (7380#)
8.1 Big block Gas/Allison 4:10 4x4
2004 Newmar Kountry Star 34 BLWB 3 Slides (15620#)
Pin Wt 2560# (16.3%) Total combination Wt=23,000#
klenger
Tucson AZ
Posted: 11/06/07 06:21am Link  |  Print  |  Notify Moderator
I've heard of rare occasions where the 1000 would not run some of the higher capacity converters with fully discharged batteries, but it should work OK for your purpose.
2008 Tiffin Allegro 32BA FRED Class A Motor Home
2008 Honda CRV, Blue Ox, SMI DUO Stay-in-Play Brake
cabanaman
middleburg florida
Posted: 11/06/07 07:07am Link  |  Print  |  Notify Moderator
I am looking at smaller generators and really need to know what kind of amperage draw RV converters have.Specifically my intellipower 9100 series converter?
* This post was edited 11/06/07 08:28am by cabanaman *
Retired Navy
2007.5 Dodge Ram SLT sport 2500 quad cab 6.7 cummins,6 speed auto with exhaust brake.
2007 Open Road 378SA4S-5 quad slide.
